[PATCH 11/15] lpc1768_mbed.cfg: Remove -DNDEBUG flag
Tue Mar 10 13:17:21 UTC 2015
On March 10, 2015 8:15:00 AM CDT, Gedare Bloom <gedare at rtems.org> wrote:
>We have to be careful what we say. Assert() is generally a useful
>construct. We just need to define its use correctly, especially in the
>shared code regions.
We should not use assert() but the proper internal RTEMS equivalent. We also should be careful not to bring a system down when an error should be returned.
>Gedare
>On Mon, Mar 9, 2015 at 3:47 PM, Joel Sherrill
><joel.sherrill at oarcorp.com> wrote:
>> On March 9, 2015 2:38:19 PM CDT, "Marcos Díaz"
><marcos.diaz at tallertechnologies.com> wrote:
>>>Thanks for the answer!
>>>I can see that we shouldn't have any asserts in the code, we are
>>>submitting some changes and drivers for the lpc1768 soon and will try
>>>to delete all the asserts in that code.
>> I think the rtems assert is ok since it is tied to an RTEMS configure
>flag and disabled by default.
>> A BSP fault probably should be a fatal error if it can occur in the
>field.
>>>Thanks again!
>>>On Mon, Mar 9, 2015 at 4:31 PM, Joel Sherrill
>>>On March 9, 2015 2:25:29 PM CDT, "Marcos Díaz"
>>>>Hi!
>>>>I wanted to know which warning this raised, and how is the correct
>way
>>>>to set this flag in production code?
>>>First, there should be no assert's in cpukit so those there should be
>>>fixed. I think the same applies for BSPs.
>>>It tripped some warnings for set but not used variables on m68k. I
>>>noticed it had -DNDEBUG which it shouldn't have, so I removed them.
>>>Adding it to CFLAGS on the configure line is the best way but there
>>>shouldn't have been any.
>>>There is a ticket for the asserts to be removed.
>>>>Thanks!
>>>>On Mon, Mar 9, 2015 at 2:38 PM, Joel Sherrill
>>>> c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed.cfg | 2 +-
>>>> 1 file changed, 1 insertion(+), 1 deletion(-)
>>>>diff --git
>a/c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed.cfg
>>>>b/c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed.cfg
>>>>index 4cf24c8..a5ed9c6 100644
>>>>--- a/c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed.cfg
>>>>+++ b/c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed.cfg
>>>>@@ -8,7 +8,7 @@ RTEMS_CPU = arm
>>>> CPU_CFLAGS = -march=armv7-m -mthumb
>>>>-CFLAGS_OPTIMIZE_V = -O2 -ggdb3 -DNDEBUG
>>>>+CFLAGS_OPTIMIZE_V = -O2 -ggdb3
>>>> BINEXT?=.bin
>>>> # This defines the operations performed on the linked executable.
>>>> # is currently required.
>>>>1.9.3
>>>>_______________________________________________
>>>>devel mailing list
>>>>devel at rtems.org
>>>>http://lists.rtems.org/mailman/listinfo/devel
>>>>Marcos Díaz
>>>>Software Engineer
>>>>San Lorenzo 47, 3rd Floor, Office 5
>>>>Córdoba, Argentina
>>>>Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
>>>>Skype: markdiaz22
>>>--joel
>>>Marcos Díaz
>>>Software Engineer
>>>Córdoba, Argentina
>>>Skype: markdiaz22
>> --joel
>> devel mailing list
>> devel at rtems.org
--joel
