[PATCH] [RSB] Use gcc 5-20150301 snapshot.
Tue Mar 10 13:19:03 UTC 2015
On Tue, Mar 10, 2015 at 5:35 AM, Hesham ALMatary
<heshamelmatary at gmail.com> wrote:
> Use newlib git repository and gcc snapshot that contains the latest moxie
> opcodes. Revert back to dtc-1.2.0 as dtc-1.4.1 would raise a compilation error.
What binutils version does it pick up?
> Note: This patch is unstable, and it's meant to be a temporary solution until
> the next gcc release,the build process may or may not fail!
What do you mean unstable? Did you build a working toolchain for moxie
with this patch applied?
> Update #2254
>  rtems/config/4.11/rtems-moxie.bset | 14 +++++++++++---
>  1 file changed, 11 insertions(+), 3 deletions(-)
> diff --git a/rtems/config/4.11/rtems-moxie.bset b/rtems/config/4.11/rtems-moxie.bset
> index 2e4962d..64c22fc 100644
> --- a/rtems/config/4.11/rtems-moxie.bset
> +++ b/rtems/config/4.11/rtems-moxie.bset
> @@ -16,14 +16,22 @@
>  %define win32-gdb-disable-sim
> +# Temporary solution until next gcc release to fix ABI changes.
> +%source set gcc ftp://ftp.mirrorservice.org/sites/sourceware.org/pub/gcc/snapshots/5-20150301/gcc-5-20150301.tar.bz2
> +# Use gcc snapshot the has moxie ABI changes
> +%define gcc_version 5-20150301
> +%define newlib_version de616601501c4f82968683e80c112604a2d40222
>  # Tools configuration.
>  4.11/rtems-autotools
>  devel/expat-2.1.0-1
> -devel/dtc-1.4.1
> -tools/rtems-binutils-2.24-1
> -tools/rtems-gcc-4.9.2-newlib-git-1
> +devel/dtc-1.2.0
> +tools/rtems-binutils-git-1
> +tools/rtems-gcc-4.9-newlib-git-1
>  tools/rtems-gdb-7.8.2-1
>  tools/rtems-tools-4.11-1
>  tools/rtems-kernel-4.11
> 2.1.0
> devel mailing list
> devel at rtems.org
