[PATCH 15/15] cpukit/libcrypt/misc.c: Conditionally correct 16-bit unclean code
Tue Mar 10 14:12:36 UTC 2015
Should be fixed now. Thanks.
On 3/10/2015 9:04 AM, Sebastian Huber wrote:
> On 09/03/15 18:38, Joel Sherrill wrote:
>>   cpukit/libcrypt/misc.c | 4 ++++
>>   1 file changed, 4 insertions(+)
>> diff --git a/cpukit/libcrypt/misc.c b/cpukit/libcrypt/misc.c
>> index 9f2c13e..9ca26d4 100644
>> --- a/cpukit/libcrypt/misc.c
>> +++ b/cpukit/libcrypt/misc.c
>> @@ -52,7 +52,11 @@ b64_from_24bit(uint8_t B2, uint8_t B1, uint8_t B0, int n, int *buflen, char **cp
>>   	uint32_t w;
>>   	int i;
>> +#if defined(__rtems__)
>>   	w = (B2 << 16) | (B1 << 8) | B0;
>> +#else
>> +	w = ((uint32_t)B2 << 16) | ((uint32_t)B1 << 8) | B0;
>> +#endif
>>   	for (i = 0; i < n; i++) {
>>   		**cp = itoa64[w&0x3f];
>>   		(*cp)++;
> Should this be the other way around?
