[PATCH] cpukit: deprecate notepads
Gedare Bloom
gedare at rtems.org
Tue Mar 10 16:53:13 UTC 2015
Deprecate Classic API Notepads. Mark task_set/get_note() with
the deprecated attribute, and also mark the notepads field.
Replace disable with enable option for notepads in confdefs.h,
and make notepads disabled by default. The previous option
CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS is now unused and
will emit a compile-time warning. A new option
CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS is available to turn
on notepads, but it also will emit a compile-time warning
to indicate that notepads are deprecated.
Closes #2265
c/src/librtems++/include/rtems++/rtemsTask.h | 4 +--
cpukit/libmisc/monitor/monitor.h | 3 +-
cpukit/rtems/include/rtems/rtems/tasks.h | 12 ++++++--
cpukit/sapi/include/confdefs.h | 10 ++++--
doc/user/conf.t | 46 +++++++++++++++++++++++++---
doc/user/task.t | 5 +++
doc/user/userext.t | 3 +-
testsuites/libtests/rtems++/System.h | 1 +
testsuites/mptests/mp02/system.h | 2 ++
testsuites/sptests/sp07/system.h | 2 ++
testsuites/sptests/spnotepad01/init.c | 1 -
testsuites/sptests/sptask_err04/system.h | 2 ++
testsuites/tmtests/tm08/system.h | 2 ++
13 files changed, 77 insertions(+), 16 deletions(-)
diff --git a/c/src/librtems++/include/rtems++/rtemsTask.h b/c/src/librtems++/include/rtems++/rtemsTask.h
index 6d19b46..6a500b0 100644
--- a/c/src/librtems++/include/rtems++/rtemsTask.h
+++ b/c/src/librtems++/include/rtems++/rtemsTask.h
@@ -127,9 +127,9 @@ public:
// notepad control
const rtems_status_code get_note(const uint32_t notepad,
- uint32_t& note);
+ uint32_t& note) RTEMS_COMPILER_DEPRECATED_ATTRIBUTE;
const rtems_status_code set_note(const uint32_t notepad,
- const uint32_t note);
+ const uint32_t note) RTEMS_COMPILER_DEPRECATED_ATTRIBUTE;
// object id, and name
const rtems_id id_is() const { return id; }
diff --git a/cpukit/libmisc/monitor/monitor.h b/cpukit/libmisc/monitor/monitor.h
index 6a85d60..799df35 100644
--- a/cpukit/libmisc/monitor/monitor.h
+++ b/cpukit/libmisc/monitor/monitor.h
@@ -104,7 +104,8 @@ typedef struct {
rtems_event_set events;
rtems_mode modes;
rtems_attribute attributes;
- uint32_t notepad[RTEMS_NUMBER_NOTEPADS];
+ uint32_t notepad[RTEMS_NUMBER_NOTEPADS]
+ RTEMS_COMPILER_DEPRECATED_ATTRIBUTE;
rtems_id wait_id;
uint32_t wait_args;
uint32_t ticks;
diff --git a/cpukit/rtems/include/rtems/rtems/tasks.h b/cpukit/rtems/include/rtems/rtems/tasks.h
index e0fa27e..237ec19 100644
--- a/cpukit/rtems/include/rtems/rtems/tasks.h
+++ b/cpukit/rtems/include/rtems/rtems/tasks.h
@@ -271,6 +271,8 @@ rtems_status_code rtems_task_delete(
* @brief RTEMS Get Task Node
+ * @deprecated Notepads are deprecated and will be removed.
* This routine implements the rtems_task_get_note directive. The
* value of the indicated notepad for the task associated with ID
* is returned in note.
@@ -285,11 +287,13 @@ rtems_status_code rtems_task_get_note(
rtems_id id,
uint32_t notepad,
uint32_t *note
+) RTEMS_COMPILER_DEPRECATED_ATTRIBUTE;
* @brief RTEMS Set Task Note
* This routine implements the rtems_task_set_note directive. The
@@ -306,7 +310,7 @@ rtems_status_code rtems_task_set_note(
rtems_id id,
uint32_t notepad,
uint32_t note
* @brief RTEMS Task Mode
@@ -663,10 +667,12 @@ typedef struct {
* This field contains the notepads for this task.
* @note MUST BE LAST ENTRY.
- uint32_t Notepads[ RTEMS_ZERO_LENGTH_ARRAY ];
+ uint32_t Notepads[ RTEMS_ZERO_LENGTH_ARRAY ] RTEMS_COMPILER_DEPRECATED_ATTRIBUTE;
} RTEMS_API_Control;
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 7d9e3b9..0bebb4e 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -1810,7 +1810,11 @@ const rtems_libio_helper rtems_fs_init_helper =
#define CONFIGURE_TASKS \
(CONFIGURE_MAXIMUM_TASKS + CONFIGURE_LIBBLOCK_TASKS)
- #ifndef CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS
+ #if defined(CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS)
+ #warning "CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS is deprecated and will be removed."
+ #endif
+ #if defined(CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS)
+ #warning "CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS is deprecated and will be removed."
#define CONFIGURE_NOTEPADS_ENABLED TRUE
#else
#define CONFIGURE_NOTEPADS_ENABLED FALSE
@@ -2613,8 +2617,8 @@ const rtems_libio_helper rtems_fs_init_helper =
#endif
} Scheduler;
RTEMS_API_Control API_RTEMS;
- uint32_t Notepads[ RTEMS_NUMBER_NOTEPADS ];
+ uint32_t Notepads[ RTEMS_NUMBER_NOTEPADS ] RTEMS_COMPILER_DEPRECATED_ATTRIBUTE;
#endif
#ifdef RTEMS_POSIX_API
POSIX_API_Control API_POSIX;
diff --git a/doc/user/conf.t b/doc/user/conf.t
index dc10816..fe714b4 100644
--- a/doc/user/conf.t
+++ b/doc/user/conf.t
@@ -595,6 +595,40 @@ require the addition of a new configuration parameter to specify the
number of tasks which enable floating point support.
@c
+ at c === CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS ===
+ at c
+ at subsection Enable Classic API Notepads
+ at findex CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS
+ at table @b
+ at item CONSTANT:
+ at code{CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS}
+ at item DATA TYPE:
+Boolean feature macro.
+ at item RANGE:
+Defined or undefined.
+ at item DEFAULT VALUE:
+This is not defined by default, and Classic API Notepads are not supported.
+ at end table
+ at subheading DESCRIPTION:
+ at code{CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS} should be defined if the
+user wants to have support for Classic API Notepads in their application.
+ at subheading NOTES:
+Disabling Classic API Notepads saves the allocation of sixteen (16)
+thirty-two bit integers. This saves sixty-four bytes per task/thread
+plus the allocation overhead. Notepads are rarely used in applications
+and this can save significant memory in a low RAM system. Classic API
+Notepads are deprecated, and this option is expected to be obsolete in
+the near future.
+ at c
@c === CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS ===
@c
@subsection Disable Classic API Notepads
@@ -612,20 +646,22 @@ Boolean feature macro.
@item DEFAULT VALUE:
-This is not defined by default, and Classic API Notepads are supported.
@end table
@subheading DESCRIPTION:
- at code{CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS} should be defined if the
-user does not want to have support for Classic API Notepads in their
-application.
+ at code{CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS} is deprecated. If users
+want to have support for Classic API Notepads, they should use
+ at code{CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS}.
@subheading NOTES:
-and this can save significant memory in a low RAM system.
+the near future.
@c
@c === CONFIGURE_MAXIMUM_TIMERS ===
diff --git a/doc/user/task.t b/doc/user/task.t
index cf7a514..5aec9b1 100644
--- a/doc/user/task.t
+++ b/doc/user/task.t
@@ -645,6 +645,7 @@ to set a task's notepad entry to a specified note. The
@code{@value{DIRPREFIX}task_get_note}
directive allows the user to obtain the note
contained in any one of the sixteen notepads of a specified task.
+Notepads are deprecated and will be removed.
@subsection Task Deletion
@@ -1515,6 +1516,8 @@ This directive returns the note contained in the notepad
location of the task specified by id.
@subheading NOTES:
+This directive is deprecated and will be removed.
This directive will not cause the running task to be preempted.
If id is set to @code{@value{RPREFIX}SELF},
@@ -1567,6 +1570,8 @@ procedure Task_Set_Note (
@code{@value{RPREFIX}INVALID_NUMBER} - invalid notepad location
This directive sets the notepad entry for the task specified by
id to the value note.
diff --git a/doc/user/userext.t b/doc/user/userext.t
index 97628bd..dc6ad4e 100644
--- a/doc/user/userext.t
+++ b/doc/user/userext.t
@@ -137,7 +137,8 @@ be used to store additional data required by the user's
extension functions. It is also possible for a user extension
to utilize the notepad locations associated with each task
although this may conflict with application usage of those
-particular notepads.
+particular notepads. However, notepads are deprecated and will
+be removed.
The TCB extension is an array of pointers in the TCB. The
index into the table can be obtained from the extension id
diff --git a/testsuites/libtests/rtems++/System.h b/testsuites/libtests/rtems++/System.h
index e787fe2..410fccb 100644
--- a/testsuites/libtests/rtems++/System.h
+++ b/testsuites/libtests/rtems++/System.h
@@ -123,6 +123,7 @@ class Io_during_interrupt
#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 0
#define CONFIGURE_TICKS_PER_TIMESLICE 100
+#define CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS
#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
diff --git a/testsuites/mptests/mp02/system.h b/testsuites/mptests/mp02/system.h
index 2ccc1e4..69025d4 100644
--- a/testsuites/mptests/mp02/system.h
+++ b/testsuites/mptests/mp02/system.h
@@ -30,6 +30,8 @@ rtems_task Test_task(
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_MAXIMUM_TASKS 2
diff --git a/testsuites/sptests/sp07/system.h b/testsuites/sptests/sp07/system.h
index 8bea0fb..c537455 100644
--- a/testsuites/sptests/sp07/system.h
+++ b/testsuites/sptests/sp07/system.h
@@ -64,6 +64,8 @@ void Task_exit_extension(
#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 2
diff --git a/testsuites/sptests/spnotepad01/init.c b/testsuites/sptests/spnotepad01/init.c
index 97a02f5..9604c32 100644
--- a/testsuites/sptests/spnotepad01/init.c
+++ b/testsuites/sptests/spnotepad01/init.c
@@ -53,7 +53,6 @@ rtems_task Init(
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
-#define CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS
#define CONFIGURE_MAXIMUM_TASKS 1
diff --git a/testsuites/sptests/sptask_err04/system.h b/testsuites/sptests/sptask_err04/system.h
index ef3e781..8fd4a14 100644
--- a/testsuites/sptests/sptask_err04/system.h
+++ b/testsuites/sptests/sptask_err04/system.h
@@ -29,6 +29,8 @@ rtems_task Task_1(
diff --git a/testsuites/tmtests/tm08/system.h b/testsuites/tmtests/tm08/system.h
index 3610fe9..6e2df2f 100644
--- a/testsuites/tmtests/tm08/system.h
+++ b/testsuites/tmtests/tm08/system.h
@@ -27,6 +27,8 @@ rtems_task Init(
#define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
#define CONFIGURE_MAXIMUM_TASKS 3
#define CONFIGURE_TICKS_PER_TIMESLICE 0
1.9.1
