[PATCH] cpukit: deprecate notepads
Tue Mar 10 17:53:04 UTC 2015
I think this is OK.
On 3/10/2015 11:55 AM, Gedare Bloom wrote:
> This supercedes the previous patch. Now it updates the doc wherever
> notepads are reference and the test cases that need notepads.
> On Tue, Mar 10, 2015 at 12:53 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> Deprecate Classic API Notepads. Mark task_set/get_note() with
>> the deprecated attribute, and also mark the notepads field.
>> Replace disable with enable option for notepads in confdefs.h,
>> and make notepads disabled by default. The previous option
>> CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS is now unused and
>> will emit a compile-time warning. A new option
>> CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS is available to turn
>> on notepads, but it also will emit a compile-time warning
>> to indicate that notepads are deprecated.
>> Closes #2265
>>  c/src/librtems++/include/rtems++/rtemsTask.h |  4 +--
>>  cpukit/libmisc/monitor/monitor.h             |  3 +-
>>  cpukit/rtems/include/rtems/rtems/tasks.h     | 12 ++++++--
>>  cpukit/sapi/include/confdefs.h               | 10 ++++--
>>  doc/user/conf.t                              | 46 +++++++++++++++++++++++++---
>>  doc/user/task.t                              |  5 +++
>>  doc/user/userext.t                           |  3 +-
>>  testsuites/libtests/rtems++/System.h         |  1 +
>>  testsuites/mptests/mp02/system.h             |  2 ++
>>  testsuites/sptests/sp07/system.h             |  2 ++
>>  testsuites/sptests/spnotepad01/init.c        |  1 -
>>  testsuites/sptests/sptask_err04/system.h     |  2 ++
>>  testsuites/tmtests/tm08/system.h             |  2 ++
>>  13 files changed, 77 insertions(+), 16 deletions(-)
>> diff --git a/c/src/librtems++/include/rtems++/rtemsTask.h b/c/src/librtems++/include/rtems++/rtemsTask.h
>> index 6d19b46..6a500b0 100644
>> --- a/c/src/librtems++/include/rtems++/rtemsTask.h
>> +++ b/c/src/librtems++/include/rtems++/rtemsTask.h
>> @@ -127,9 +127,9 @@ public:
>>    // notepad control
>>    const rtems_status_code get_note(const uint32_t notepad,
>> -                                   uint32_t& note);
>> +                                   uint32_t& note) RTEMS_COMPILER_DEPRECATED_ATTRIBUTE;
>>    const rtems_status_code set_note(const uint32_t notepad,
>> -                                   const uint32_t note);
>> +                                   const uint32_t note) RTEMS_COMPILER_DEPRECATED_ATTRIBUTE;
>>    // object id, and name
>>    const rtems_id id_is() const { return id; }
>> diff --git a/cpukit/libmisc/monitor/monitor.h b/cpukit/libmisc/monitor/monitor.h
>> index 6a85d60..799df35 100644
>> --- a/cpukit/libmisc/monitor/monitor.h
>> +++ b/cpukit/libmisc/monitor/monitor.h
>> @@ -104,7 +104,8 @@ typedef struct {
>>      rtems_event_set            events;
>>      rtems_mode                 modes;
>>      rtems_attribute            attributes;
>> -    uint32_t                   notepad[RTEMS_NUMBER_NOTEPADS];
>> +    uint32_t                   notepad[RTEMS_NUMBER_NOTEPADS]
>> +                                            RTEMS_COMPILER_DEPRECATED_ATTRIBUTE;
>>      rtems_id                   wait_id;
>>      uint32_t                   wait_args;
>>      uint32_t                   ticks;
>> diff --git a/cpukit/rtems/include/rtems/rtems/tasks.h b/cpukit/rtems/include/rtems/rtems/tasks.h
>> index e0fa27e..237ec19 100644
>> --- a/cpukit/rtems/include/rtems/rtems/tasks.h
>> +++ b/cpukit/rtems/include/rtems/rtems/tasks.h
>> @@ -271,6 +271,8 @@ rtems_status_code rtems_task_delete(
>>   * @brief RTEMS Get Task Node
>> + * @deprecated Notepads are deprecated and will be removed.
>>   * This routine implements the rtems_task_get_note directive. The
>>   * value of the indicated notepad for the task associated with ID
>>   * is returned in note.
>> @@ -285,11 +287,13 @@ rtems_status_code rtems_task_get_note(
>>    rtems_id    id,
>>    uint32_t    notepad,
>>    uint32_t   *note
>> +) RTEMS_COMPILER_DEPRECATED_ATTRIBUTE;
>>   * @brief RTEMS Set Task Note
>>   * This routine implements the rtems_task_set_note directive. The
>> @@ -306,7 +310,7 @@ rtems_status_code rtems_task_set_note(
>>    rtems_id   id,
>>    uint32_t   notepad,
>>    uint32_t   note
>>   * @brief RTEMS Task Mode
>> @@ -663,10 +667,12 @@ typedef struct {
>>     *  This field contains the notepads for this task.
>>     *  @note MUST BE LAST ENTRY.
>> -  uint32_t                 Notepads[ RTEMS_ZERO_LENGTH_ARRAY ];
>> +  uint32_t Notepads[ RTEMS_ZERO_LENGTH_ARRAY ] RTEMS_COMPILER_DEPRECATED_ATTRIBUTE;
>>  }  RTEMS_API_Control;
>> diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
>> index 7d9e3b9..0bebb4e 100644
>> --- a/cpukit/sapi/include/confdefs.h
>> +++ b/cpukit/sapi/include/confdefs.h
>> @@ -1810,7 +1810,11 @@ const rtems_libio_helper rtems_fs_init_helper =
>>    #define CONFIGURE_TASKS \
>>      (CONFIGURE_MAXIMUM_TASKS + CONFIGURE_LIBBLOCK_TASKS)
>> -  #ifndef CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS
>> +  #if defined(CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS)
>> +    #warning "CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS is deprecated and will be removed."
>> +  #endif
>> +  #if defined(CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS)
>> +    #warning "CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS is deprecated and will be removed."
>>      #define CONFIGURE_NOTEPADS_ENABLED           TRUE
>>    #else
>>      #define CONFIGURE_NOTEPADS_ENABLED           FALSE
>> @@ -2613,8 +2617,8 @@ const rtems_libio_helper rtems_fs_init_helper =
>>        #endif
>>      } Scheduler;
>>      RTEMS_API_Control API_RTEMS;
>> -      uint32_t Notepads[ RTEMS_NUMBER_NOTEPADS ];
>> +      uint32_t Notepads[ RTEMS_NUMBER_NOTEPADS ] RTEMS_COMPILER_DEPRECATED_ATTRIBUTE;
>>      #endif
>>      #ifdef RTEMS_POSIX_API
>>        POSIX_API_Control API_POSIX;
>> diff --git a/doc/user/conf.t b/doc/user/conf.t
>> index dc10816..fe714b4 100644
>> --- a/doc/user/conf.t
>> +++ b/doc/user/conf.t
>> @@ -595,6 +595,40 @@ require the addition of a new configuration parameter to specify the
>>  number of tasks which enable floating point support.
>>  @c
>> + at c === CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS ===
>> + at c
>> + at subsection Enable Classic API Notepads
>> + at findex CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS
>> + at table @b
>> + at item CONSTANT:
>> + at code{CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS}
>> + at item DATA TYPE:
>> +Boolean feature macro.
>> + at item RANGE:
>> +Defined or undefined.
>> + at item DEFAULT VALUE:
>> +This is not defined by default, and Classic API Notepads are not supported.
>> + at end table
>> + at subheading DESCRIPTION:
>> + at code{CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS} should be defined if the
>> +user wants to have support for Classic API Notepads in their application.
>> + at subheading NOTES:
>> +Disabling Classic API Notepads saves the allocation of sixteen (16)
>> +thirty-two bit integers. This saves sixty-four bytes per task/thread
>> +plus the allocation overhead. Notepads are rarely used in applications
>> +and this can save significant memory in a low RAM system. Classic API
>> +Notepads are deprecated, and this option is expected to be obsolete in
>> +the near future.
>> + at c
>>  @c === CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS ===
>>  @c
>>  @subsection Disable Classic API Notepads
>> @@ -612,20 +646,22 @@ Boolean feature macro.
>>  @item DEFAULT VALUE:
>> -This is not defined by default, and Classic API Notepads are supported.
>>  @end table
>>  @subheading DESCRIPTION:
>> - at code{CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS} should be defined if the
>> -user does not want to have support for Classic API Notepads in their
>> -application.
>> + at code{CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS} is deprecated. If users
>> +want to have support for Classic API Notepads, they should use
>> + at code{CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS}.
>>  @subheading NOTES:
>> -and this can save significant memory in a low RAM system.
>> +the near future.
>>  @c
>>  @c === CONFIGURE_MAXIMUM_TIMERS ===
>> diff --git a/doc/user/task.t b/doc/user/task.t
>> index cf7a514..5aec9b1 100644
>> --- a/doc/user/task.t
>> +++ b/doc/user/task.t
>> @@ -645,6 +645,7 @@ to set a task's notepad entry to a specified note.  The
>>  @code{@value{DIRPREFIX}task_get_note}
>>  directive allows the user to obtain the note
>>  contained in any one of the sixteen notepads of a specified task.
>> +Notepads are deprecated and will be removed.
>>  @subsection Task Deletion
>> @@ -1515,6 +1516,8 @@ This directive returns the note contained in the notepad
>>  location of the task specified by id.
>>  @subheading NOTES:
>> +This directive is deprecated and will be removed.
>>  This directive will not cause the running task to be preempted.
>>  If id is set to @code{@value{RPREFIX}SELF},
>> @@ -1567,6 +1570,8 @@ procedure Task_Set_Note (
>>  @code{@value{RPREFIX}INVALID_NUMBER} - invalid notepad location
>>  This directive sets the notepad entry for the task specified by
>>  id to the value note.
>> diff --git a/doc/user/userext.t b/doc/user/userext.t
>> index 97628bd..dc6ad4e 100644
>> --- a/doc/user/userext.t
>> +++ b/doc/user/userext.t
>> @@ -137,7 +137,8 @@ be used to store additional data required by the user's
>>  extension functions.  It is also possible for a user extension
>>  to utilize the notepad locations associated with each task
>>  although this may conflict with application usage of those
>> -particular notepads.
>> +particular notepads. However, notepads are deprecated and will
>> +be removed.
>>  The TCB extension is an array of pointers in the TCB. The
>>  index into the table can be obtained from the extension id
>> diff --git a/testsuites/libtests/rtems++/System.h b/testsuites/libtests/rtems++/System.h
>> index e787fe2..410fccb 100644
>> --- a/testsuites/libtests/rtems++/System.h
>> +++ b/testsuites/libtests/rtems++/System.h
>> @@ -123,6 +123,7 @@ class Io_during_interrupt
>>  #define CONFIGURE_MAXIMUM_USER_EXTENSIONS     0
>>  #define CONFIGURE_TICKS_PER_TIMESLICE       100
>> +#define CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS
>>  #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>>  #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> diff --git a/testsuites/mptests/mp02/system.h b/testsuites/mptests/mp02/system.h
>> index 2ccc1e4..69025d4 100644
>> --- a/testsuites/mptests/mp02/system.h
>> +++ b/testsuites/mptests/mp02/system.h
>> @@ -30,6 +30,8 @@ rtems_task Test_task(
>>  #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>>  #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>>  #define CONFIGURE_MAXIMUM_TASKS               2
>> diff --git a/testsuites/sptests/sp07/system.h b/testsuites/sptests/sp07/system.h
>> index 8bea0fb..c537455 100644
>> --- a/testsuites/sptests/sp07/system.h
>> +++ b/testsuites/sptests/sp07/system.h
>> @@ -64,6 +64,8 @@ void Task_exit_extension(
>>  #define CONFIGURE_MAXIMUM_USER_EXTENSIONS     2
>> diff --git a/testsuites/sptests/spnotepad01/init.c b/testsuites/sptests/spnotepad01/init.c
>> index 97a02f5..9604c32 100644
>> --- a/testsuites/sptests/spnotepad01/init.c
>> +++ b/testsuites/sptests/spnotepad01/init.c
>> @@ -53,7 +53,6 @@ rtems_task Init(
>>  #define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
>> -#define CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS
>>  #define CONFIGURE_MAXIMUM_TASKS         1
>> diff --git a/testsuites/sptests/sptask_err04/system.h b/testsuites/sptests/sptask_err04/system.h
>> index ef3e781..8fd4a14 100644
>> --- a/testsuites/sptests/sptask_err04/system.h
>> +++ b/testsuites/sptests/sptask_err04/system.h
>> @@ -29,6 +29,8 @@ rtems_task Task_1(
>> diff --git a/testsuites/tmtests/tm08/system.h b/testsuites/tmtests/tm08/system.h
>> index 3610fe9..6e2df2f 100644
>> --- a/testsuites/tmtests/tm08/system.h
>> +++ b/testsuites/tmtests/tm08/system.h
>> @@ -27,6 +27,8 @@ rtems_task Init(
>>  #define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
>>  #define CONFIGURE_MAXIMUM_TASKS              3
>>  #define CONFIGURE_TICKS_PER_TIMESLICE        0
>> 1.9.1
> devel mailing list
> devel at rtems.org
