[PATCH] cpukit: deprecate task variables. closes #2293.
Gedare Bloom
gedare at rtems.org
Tue Mar 10 19:47:04 UTC 2015
cpukit/rtems/include/rtems/rtems/tasks.h | 12 +++++++++---
cpukit/rtems/include/rtems/rtems/tasksimpl.h | 4 +++-
cpukit/sapi/include/confdefs.h | 3 +++
doc/user/task.t | 11 +++++++++++
4 files changed, 26 insertions(+), 4 deletions(-)
diff --git a/cpukit/rtems/include/rtems/rtems/tasks.h b/cpukit/rtems/include/rtems/rtems/tasks.h
index 237ec19..dc12d0b 100644
--- a/cpukit/rtems/include/rtems/rtems/tasks.h
+++ b/cpukit/rtems/include/rtems/rtems/tasks.h
@@ -462,6 +462,8 @@ rtems_status_code rtems_task_is_suspended(
* @brief RTEMS Add Task Variable
+ * @deprecated Task variables are deprecated.
* This directive adds a per task variable.
* @note This service is not available in SMP configurations.
@@ -470,11 +472,13 @@ rtems_status_code rtems_task_variable_add(
rtems_id tid,
void **ptr,
void (*dtor)(void *)
+) RTEMS_COMPILER_DEPRECATED_ATTRIBUTE;
* @brief Get a per-task variable
* This directive gets the value of a task variable.
@@ -483,11 +487,13 @@ rtems_status_code rtems_task_variable_get(
rtems_id tid,
void **ptr,
void **result
* @brief RTEMS Delete Task Variable
* This directive removes a per task variable.
@@ -495,7 +501,7 @@ rtems_status_code rtems_task_variable_get(
rtems_status_code rtems_task_variable_delete(
rtems_id tid,
void **ptr
#endif
#if defined(__RTEMS_HAVE_SYS_CPUSET_H__)
diff --git a/cpukit/rtems/include/rtems/rtems/tasksimpl.h b/cpukit/rtems/include/rtems/rtems/tasksimpl.h
index 280be2f..b8f91d3 100644
--- a/cpukit/rtems/include/rtems/rtems/tasksimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/tasksimpl.h
@@ -70,13 +70,15 @@ void _RTEMS_tasks_Initialize_user_tasks( void );
* @brief RTEMS Tasks Invoke Task Variable Destructor
* This routine invokes the optional user provided destructor on the
* task variable and frees the memory for the task variable.
void _RTEMS_Tasks_Invoke_task_variable_dtor(
Thread_Control *the_thread,
rtems_task_variable_t *tvp
#endif
RTEMS_INLINE_ROUTINE Thread_Control *_RTEMS_tasks_Allocate(void)
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 0bebb4e..2b4e27f 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -1823,6 +1823,8 @@ const rtems_libio_helper rtems_fs_init_helper =
* This macro calculates the memory required for task variables.
* Each task variable is individually allocated from the Workspace.
* Hence, we do the multiplication on the configured size.
@@ -1839,6 +1841,7 @@ const rtems_libio_helper rtems_fs_init_helper =
#define CONFIGURE_MAXIMUM_TASK_VARIABLES 0
#define CONFIGURE_MEMORY_FOR_TASK_VARIABLES(_task_variables) 0
#else
+ #warning "Per-Task Variables are deprecated and will be removed."
#define CONFIGURE_MEMORY_FOR_TASK_VARIABLES(_task_variables) \
(_task_variables) * \
_Configure_From_workspace(sizeof(rtems_task_variable_t))
diff --git a/doc/user/task.t b/doc/user/task.t
index 5aec9b1..5606c4a 100644
--- a/doc/user/task.t
+++ b/doc/user/task.t
@@ -308,6 +308,8 @@ generally result in an exception condition.
@cindex per task variables
+Per task variables are deprecated, see the warning below.
Per task variables are used to support global variables whose value
may be unique to a task. After indicating that a variable should be
treated as private (i.e. per-task) the task can access and modify the
@@ -346,6 +348,9 @@ that task is the logical owner of the value in the per-task variable's
location. There is no way for a single memory image to contain the
correct value for each task executing on each core. Consequently,
per-task variables are disabled in SMP configurations of RTEMS.
+Instead the application developer should
+consider the use of POSIX Keys or Thread Local Storage (TLS). POSIX Keys
+are not enabled in all RTEMS configurations.
@subsection Building a Task Attribute Set
@@ -1787,6 +1792,8 @@ passed to the destructor function is the task's value of the variable.
@subheading NOTES:
+This directive is deprecated and task variables will be removed.
Task variables increase the context switch time to and from the
tasks that own them so it is desirable to minimize the number of
task variables. One efficient method
@@ -1844,6 +1851,8 @@ task, which can get its private value by directly accessing the variable.
@subheading NOTES:
If you change memory which @code{task_variable_value} points to,
remember to declare that memory as volatile, so that the compiler
will optimize it correctly. In this case both the pointer
@@ -1895,6 +1904,8 @@ This directive removes the given location from a task's context.
@subheading NOTES:
Per-task variables are disabled in SMP configurations and this service
is not available.
1.9.1
