New source layout.
Wed Mar 11 08:44:04 UTC 2015
On 09/03/15 18:02, Amar Takhar wrote:
> On 2015-03-09 14:18 +0100, Sebastian Huber wrote:
>> >This is actually a big problem and will break a lot of thinks. Currently
>> >you use
>> >#include <bsp.h>
>> >and get for example RTEMS_BSP_NETWORK_DRIVER_ATTACH for the network
>> >configuration.
>> >You find the <bsp.h> via the -B compiler switch.
> This will be changed so it is no longer required.  The real problem is that we
> have to use multiple -I and -B.
> The waf build does not use -B anywhere yet it works perfectly fine.  All I am
> proposing is unwinding all the include hacks that I added and being explicit.
We need at least three -I options, one for the BSP headers, one for the
CPU headers and one for the rest.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
