GSOC 2015 Aspirant for Improving the Raspberry Pi BSP for RTEMS
Gedare Bloom gedare at gwu.edu
Wed Mar 11 17:46:05 UTC 2015
There was an email thread about this recently, see [1]. I think there
is plenty of work to do. If you have a Rasberry Pi 2, then
you may consider adding it as a BSP variant and getting SMP
working on it as a nice project. You should ideally demonstrate that
you can build the tools and boot RTEMS on the RPi.
I think there is enough work available for up to 3 students to do
Raspberry Pi improvements. We will work with accepted students to
delineate the scope of work for each, but for the proposal phase I
encourage you to investigate the most interesting (to you) projects
for the Pi.
[1] https://lists.rtems.org/pipermail/devel/2015-March/010181.html
Gedare
On Wed, Mar 11, 2015 at 12:56 PM, Saket Sinha <saket.sinha89 at gmail.com> wrote:
> Hi,
> I would like to participate to Google Summer of Code 2015 by
> contributing to Improving the Raspberry Pi BSP for RTEMS.
> I have tracked the work from previous GSOC on this project and have found
> GPIO, SPI and I2C are already covered.
> Kindly let me know what  the peripherals that are planned to be supported in
> this GSOC for Raspberry PI.
> Regards,
> Saket Sinha
> devel mailing list
> devel at rtems.org
