rtems-source-builder on cygwin/64
emanuel stiebler emu at e-bbes.com
Wed Mar 11 17:59:00 UTC 2015
On 2015-03-11 18:40, Joel Sherrill wrote:
> On 3/11/2015 12:12 PM, emanuel stiebler wrote:
>> Hi all,
>> should it work at the moment?
> Since Chris is likely the best one to answer that and he won't be
> online for at least a a few hours, give it a try. You will know the
> answer before he wakes up. :)
I'm on cygwin, and it sits after just few hundred lines in
/bin/sh ./libtool --silent --mode=link gcc -O2 -pipe
-I/cygdrive/d/_home/emu/RTEMS.Work/rtems-source-builder/rtems/build/tmp/sb-emu/4.10/rtems-arm/opt/rtems-4.11/include
-std=gnu99 -I./lib -I. -g -O2 -Wall -Wmissing-prototypes
-Wstrict-prototypes -fexceptions  -DHAVE_EXPAT_CONFIG_H -no-undefined
-version-info 7:0:6 -rpath /opt/rtems-4.11/lib
-L/cygdrive/d/_home/emu/RTEMS.Work/rtems-source-builder/rtems/build/tmp/sb-emu/4.10/rtems-arm/opt/rtems-4.11/lib
-o libexpat.la lib/xmlparse.lo lib/xmltok.lo lib/xmlrole.lo
and cpu usage goes back to 0% ...
