rtems-source-builder on cygwin/64
Wed Mar 11 18:52:49 UTC 2015
On 3/11/2015 12:59 PM, emanuel stiebler wrote:
> On 2015-03-11 18:40, Joel Sherrill wrote:
>> On 3/11/2015 12:12 PM, emanuel stiebler wrote:
>>> Hi all,
>>> should it work at the moment?
>> Since Chris is likely the best one to answer that and he won't be
>> online for at least a a few hours, give it a try. You will know the
>> answer before he wakes up. :)
> I'm on cygwin, and it sits after just few hundred lines in
> /bin/sh ./libtool --silent --mode=link gcc -O2 -pipe
> -I/cygdrive/d/_home/emu/RTEMS.Work/rtems-source-builder/rtems/build/tmp/sb-emu/4.10/rtems-arm/opt/rtems-4.11/include
> -std=gnu99 -I./lib -I. -g -O2 -Wall -Wmissing-prototypes
> -Wstrict-prototypes -fexceptions  -DHAVE_EXPAT_CONFIG_H -no-undefined
> -version-info 7:0:6 -rpath /opt/rtems-4.11/lib
> -L/cygdrive/d/_home/emu/RTEMS.Work/rtems-source-builder/rtems/build/tmp/sb-emu/4.10/rtems-arm/opt/rtems-4.11/lib
> -o libexpat.la lib/xmlparse.lo lib/xmltok.lo lib/xmlrole.lo
> and cpu usage goes back to 0% ...
There should be a log file rsb-* with more details. Without that,
we are just guessing.
> devel mailing list
> devel at rtems.org
