rtems-source-builder on cygwin/64
emanuel stiebler emu at e-bbes.com
Thu Mar 12 06:52:54 UTC 2015
On 2015-03-12 02:56, Chris Johns wrote:> On 12/03/2015 4:59 am, emanuel
stiebler wrote:
 >> On 2015-03-11 18:40, Joel Sherrill wrote:
 >>> On 3/11/2015 12:12 PM, emanuel stiebler wrote:
 >>>> Hi all,
 >>>> should it work at the moment?
 >>> Since Chris is likely the best one to answer that and he won't be
 >>> online for at least a a few hours, give it a try. You will know the
 >>> answer before he wakes up. :)
 > I do not test cygwin but will accept patches if they look ok.
OK, is there a option which downloads and patches everything and then
tries do compile?
And, where to change the "-j 8" on the makefiles?
I noticed, that sometimes cygwin doesn't get the "process finished"
right and waits. So for debugging, "-j 1" should be better ..
