rtems-source-builder on cygwin/64
Thu Mar 12 10:11:13 UTC 2015
On 12/03/2015 5:52 pm, emanuel stiebler wrote:
> On 2015-03-12 02:56, Chris Johns wrote:> On 12/03/2015 4:59 am, emanuel
> stiebler wrote:
>  >> On 2015-03-11 18:40, Joel Sherrill wrote:
>  >>> On 3/11/2015 12:12 PM, emanuel stiebler wrote:
>  >>>> Hi all,
>  >>>> should it work at the moment?
>  >>> Since Chris is likely the best one to answer that and he won't be
>  >>> online for at least a a few hours, give it a try. You will know the
>  >>> answer before he wakes up. :)
>  > I do not test cygwin but will accept patches if they look ok.
> OK, is there a option which downloads and patches everything and then
> tries do compile?
I am not sure I understand. To get the latest RSB changes just do a pull
with git, that is 'git pull' in the RSB clone. The RSB will download all
the required source and patch it when building.
> And, where to change the "-j 8" on the makefiles?
> I noticed, that sometimes cygwin doesn't get the "process finished"
> right and waits. So for debugging, "-j 1" should be better ..
Pass '--jobs=none' to the RBS as an option.
