rtems-source-builder on cygwin/64
emu at e-bbes.com emu at e-bbes.com
Thu Mar 12 11:38:55 UTC 2015
Zitat von Chris Johns <chrisj at rtems.org>:
> On 12/03/2015 5:52 pm, emanuel stiebler wrote:
>> OK, is there a option which downloads and patches everything and then
>> tries do compile?
> I am not sure I understand. To get the latest RSB changes just do a
> pull with git, that is 'git pull' in the RSB clone. The RSB will
> download all the required source and patch it when building.
Yes, I see. It downloads the source, the patches, patches and
compiles, and gets the next package.
I wanted to download everything first, and then try to compile.
(slow network at home)
>> And, where to change the "-j 8" on the makefiles?
>> I noticed, that sometimes cygwin doesn't get the "process finished"
>> right and waits. So for debugging, "-j 1" should be better ..
> Pass '--jobs=none' to the RBS as an option.
Will try, thanks!
