[PATCH 1/2 v2] Use latest <semaphore.h> from FreeBSD for RTEMS
Thu Mar 12 13:17:30 UTC 2015
Import the latest <semaphore.h> from FreeBSD and adjust it for RTEMS.
The OpenMP support from GCC (libgomp) needs a <semaphore.h>.
Delete SEM_VALUE_MAX from the original FreeBSD version since this is
defined in <limits.h> for RTEMS.
newlib/ChangeLog
2015-03-12  Sebastian Huber  <sebastian.huber at embedded-brains.de>
    	* libc/sys/rtems/include/semaphore.h: Import from FreeBSD.
 newlib/libc/sys/rtems/include/semaphore.h | 56 +++++++++++++++++++++++++++++++
 1 file changed, 56 insertions(+)
 create mode 100644 newlib/libc/sys/rtems/include/semaphore.h
diff --git a/newlib/libc/sys/rtems/include/semaphore.h b/newlib/libc/sys/rtems/include/semaphore.h
new file mode 100644
index 0000000..e3c61da
--- /dev/null
+++ b/newlib/libc/sys/rtems/include/semaphore.h
@@ -0,0 +1,56 @@
+ * Copyright (c) 2010 David Xu <davidxu at freebsd.org>
+ * All rights reserved.
+ * are met:
+ *    notice unmodified, this list of conditions, and the following
+ *    disclaimer.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
+ * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
+ * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+ * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+ * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
+ * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * $FreeBSD$
+/* semaphore.h: POSIX 1003.1b semaphores */
+#ifndef _SEMAPHORE_H_
+#define _SEMAPHORE_H_
+#include <sys/cdefs.h>
+#include <sys/_types.h>
+#include <sys/_timespec.h>
+typedef	__uint32_t	sem_t;
+#define	SEM_FAILED	((sem_t *)0)
+__BEGIN_DECLS
+int	 sem_close(sem_t *);
+int	 sem_destroy(sem_t *);
+int	 sem_getvalue(sem_t * __restrict, int * __restrict);
+int	 sem_init(sem_t *, int, unsigned int);
+sem_t	*sem_open(const char *, int, ...);
+int	 sem_post(sem_t *);
+int	 sem_timedwait(sem_t * __restrict, const struct timespec * __restrict);
+int	 sem_trywait(sem_t *);
+int	 sem_unlink(const char *);
+int	 sem_wait(sem_t *);
+__END_DECLS
+#endif /* !_SEMAPHORE_H_ */
1.8.4.5
