New source layout.
Thu Mar 12 13:45:25 UTC 2015
On Thu, Mar 12, 2015 at 9:21 AM, Amar Takhar <amar at rtems.org> wrote:
> On 2015-03-12 14:19 +0100, Sebastian Huber wrote:
>> On 12/03/15 14:13, Amar Takhar wrote:
>> > On 2015-03-12 14:10 +0100, Sebastian Huber wrote:
>> >>> #include <rtems/sparc/cpu.h>
>> >>> #include <rtems/score/percpu.h>
>> >> This will not work. We have sparc, arm, powerpc etc. and they must not
>> >> be visible at the same time.
>> > What do you mean by 'visible'?
>> If I build for arm, then I need the arm <rtems/score/cpu.h> and not the
>> one for sparc or powerpc.
> I wasn't clear.  Wherever you include 'percpu.h' you would include the correct
> cpu.h above it and remove the #include <...cpu.h> from percpu.h.
This doesn't work in supposedly CPU-independent source code files.
Let's take percpu.h as an example. We need to include it in
<rtems/score/thread.h> -- the main header for thread scheduling that
is included by virtually every source file in the supercore. We can't
include the CPU-dependent headers here, unless we use the CPP #if-elif
cascase as mentioned by Sebastian.
Gedare
> Amar.
> devel mailing list
> devel at rtems.org
