Detecting Tests Which Don't Have Enough Workspace
Joel Sherrill
joel.sherrill at oarcorp.com
Thu Mar 12 17:41:44 UTC 2015
Hi
Many BSPs can link a test but don't actually have enough memory
to run the test. They will fail in the first few lines when the requested
memory for the RTEMS work area is not available. I hacked together
a script which adds together the code, data, bss, work space and
stack space requested. If this exceeds physical memory on the board,
then the test will fail. It is possible to come close and still run out of
memory during initialization (e.g. malloc, etc) but this approach could
detect some tests which will fail by inspecting them on the host.
This is a shell script but would be better built into the rtems-tools
and using the gdb/mi. Combined with information on the
available memory on the target, we could throw out some obvious
failure cases without touching hardware.
Thoughts?
#! /bin/sh
if [ $# -le 2 ] ; then
echo "Usage: $0 ARCH EXE ..."
exit 1
fi
ARCH=$1
shift
target=${ARCH}-rtems4.11
type ${ARCH}-rtems4.11-size >/dev/null 2>&1
if [ $? -ne 0 ] ; then
echo "${ARCH} does not appear to have RTEMS 4.11 tools installed"
exit 1
fi
extract_size()
( echo "p Configuration.work_space_size" ; \
echo "quit" ) | ${target}-gdb ${exe} 2>&1 | grep "\$1" | \
cut -d'=' -f2
for exe in $*
do
image_size=`${target}-size ${exe} | tail -1 | cut -f4`
wkspace_size=`extract_size Configuration.work_space_size`
stackspace_size=`extract_size Configuration.stack_space_size`
#echo ${image_size} ${wkspace_size} ${stackspace_size}
total=`echo ${image_size} ${wkspace_size} + ${stackspace_size} + p | dc`
echo ${total} ${exe}
done
exit 0
