rtems-source-builder on cygwin/64
Thu Mar 12 21:03:36 UTC 2015
On 12/03/2015 10:38 pm, emu at e-bbes.com wrote:
> Zitat von Chris Johns <chrisj at rtems.org>:
>> On 12/03/2015 5:52 pm, emanuel stiebler wrote:
>>> OK, is there a option which downloads and patches everything and then
>>> tries do compile?
>> I am not sure I understand. To get the latest RSB changes just do a
>> pull with git, that is 'git pull' in the RSB clone. The RSB will
>> download all the required source and patch it when building.
> Yes, I see. It downloads the source, the patches, patches and compiles,
> and gets the next package.
> I wanted to download everything first, and then try to compile.
> (slow network at home)
Try adding the options '--dry-run --with-download' to your normal RSB
command line.
It should create and download the source into the source directory and
patches into the patches directory.
