rtems-source-builder on cygwin/64
emanuel stiebler emu at e-bbes.com
Fri Mar 13 08:37:22 UTC 2015
On 2015-03-13 05:55, Chris Johns wrote:
> Have a look in this line ...
> https://git.rtems.org/rtems-source-builder/tree/source-builder/sb/windows.py#n56
> .. and remove line 57 and make line 58 'host_triple = build_triple' so
> the host and build names are the same by default.
> If this works you might then be able to remove line 53 and allow 32bit
> or 64bit.
error: failed to load CYGWIN_NT-6.1 host support
Build FAILED
So I guess there more to copy ...
