GSoC 2015 - Raspberry Pi improvements
Gedare Bloom gedare at gwu.edu
Fri Mar 13 16:46:48 UTC 2015
You should read the blog pages starting at
http://alanstechnotes.blogspot.com/2013/03/rtems-on-raspberry-pi.html
There are a few blog posts there. Some is outdated but mostly it
should work I guess, using git.rtems,org for the git repositories now
that all support is in "upstream" RTEMS Project repos.
-Gedare
On Fri, Mar 13, 2015 at 12:39 PM, Rohini Kulkarni <krohini1593 at gmail.com> wrote:
> Hi,
> I am new to using Raspberry pi. I saw the  READ ME for Raspberry pi BSP. I
> have got the files stated there, except the config.txt. I also read some
> steps on the Raspberry pi website regarding getting the image onto the SD
> card.
> Also, I do not understand what the stripping step will do. I need some help
> to figure  out booting RTEMS on the board.
> Thanks!
> On 11 Mar 2015 19:29, "Gedare Bloom" <gedare at gwu.edu> wrote:
>> On Wed, Mar 11, 2015 at 9:52 AM, Rohini Kulkarni <krohini1593 at gmail.com>
>> wrote:
>> > Hi,
>> > I am interested in contributing to this project. I referred the page
>> > Raspberry Pi improvements and also took a look at the work done under
>> > GSoc2013. It would be great if the mentors could help me with some
>> > queries.
>> > [1] Is there any reference for already proposed ideas. On the page
>> > Beagle
>> > BSP improvements , I saw a list of missing peripherals. Is there such a
>> > list
>> > for Raspberry Pi as well?
>> There was an email thread about this recently, see [1]. I think there
>> is plenty of work to do.
>> > [2] What are the requirements and how should I proceed for this project.
>> You need to own a Raspberry Pi, or a Raspberry Pi 2. If you have an
>> RPi2, you may consider adding it as a BSP variant and getting SMP
>> working on it as a nice project. You should ideally demonstrate that
>> you can build the tools and boot RTEMS on the RPi.
>> [1] https://lists.rtems.org/pipermail/devel/2015-March/010181.html
>> > Thanks!
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
