Detecting Tests Which Don't Have Enough Workspace
Sat Mar 14 00:02:02 UTC 2015
On 13/03/2015 7:29 pm, Sebastian Huber wrote:
> On 12/03/15 18:41, Joel Sherrill wrote:
>> Hi
>> Many BSPs can link a test but don't actually have enough memory
>> to run the test. They will fail in the first few lines when the requested
>> memory for the RTEMS work area is not available. I hacked together
>> a script which adds together the code, data, bss, work space and
>> stack space requested. If this exceeds physical memory on the board,
>> then the test will fail.  It is possible to come close and still run
>> out of
>> memory during initialization (e.g. malloc, etc) but this approach could
>> detect some tests which will fail by inspecting them on the host.
>> This is a shell script but would be better built into the rtems-tools
>> and using the gdb/mi. Combined with information on the
>> available memory on the target, we could throw out some obvious
>> failure cases without touching hardware.
>> Thoughts?
> I would address this with better test output, so that you can get a
> summery and see "X tests failed due to not enough memory for the
> workspace".
+1
