Fwd: [PATCH 000/111] GRLIB/LEON RTEMS RCC patches
Sat Mar 14 00:25:23 UTC 2015
On 11/03/2015 1:27 am, Karel Gardas wrote:
> On 03/ 9/15 08:31 PM, Amar Takhar wrote:
>> On 2015-03-09 14:23 -0400, Gedare Bloom wrote:
>>> We are close to branching 4.11, but I think there may be value in
>>> merging the patch set for 4.11. Would it be acceptable to all if we
>> <snip>
>> I would be against this.  The patch is too large to land just before
>> we cut
>> 4.11.  With the new waf build system we'll be moving to a more rapid
>> release
>> cycle I do not see a reason we cannot do this with 4.x.
> Yes, this is a big patch but if you do not merge it now and later
> following waf work you do tree/file placement refactoring than the patch
> would be even harder to merge.
Yes I tend to see this as important. It will be less overall work to
merge before the source is changed.
My support for merging sooner rather than latter is conditional on
Daniel and team ensuring the SPARC and LEON BSP are tested and there are
no regressions for 4.11.
