Branching 4.11
Sat Mar 14 01:03:54 UTC 2015
On Fri, Mar 13, 2015 at 8:38 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 14/03/2015 12:30 am, Gedare Bloom wrote:
>> I would like to consider landing the drvmgr and pci patch-set as a
>> sparc-specific feature (e.g. only included in builds for sparc.)
> How is this controlled or are you saying we state in the release notes this
> is only currently tested on SPARC BSPs ?
Correct.
>> The
>> code is effectively being used by sparc users already via RCC. The bad
>> thing is it is a lot of "untested code" (from an RTEMS Project
>> perspective),
> I could not see any tests in the patch set. This is currently my main issue
> with merging now. Adding code to cpukit tree should have some tests. The
> drvmgr tests should be able to run on any BSP.
I agree, but I see this taking much more time due to the nature of
hardware. We'll need some dummy drivers to exercise the drvmgr. I'd be
happy to see this work taken up in a GSoC, but it will definitely be
needed to move the code out of "sparc-specific"
>> but we have no means to test it effectively anyways
>> since it is all hardware-dependent.
> Yes there is the issue of on going testing of some of the drivers added. I
> suspect we need a commercial simulator to test. The buildbot work Amar is
> doing should support slaves so it would be nice to see publicly a commitment
> we can get access to a build slave hosted by someone with a suitable
> simulator.
This is above my pay-grade.
> Chris
