GSOC 2015: Run Time Tracing
Sat Mar 14 01:29:12 UTC 2015
On 11/03/2015 4:17 am, Richa Sehgal wrote:
> I am Richa Sehgal currently pursuing Master’s at University of Illinois
> Urbana Champaign, USA. I did my undergraduate from Indian Institute of
> Technology Delhi (IIT-Delhi).
> I am interested in contributing to the Run Time Tracing project in GSOC
> 2015.
Thank for your interest.
> I went through the project details on:
> https://devel.rtems.org/wiki/Developer/Projects/Open/TraceTool.
> It mentions the work done in past by 2 GSOC students in 2008 and 2009.
> Further, it says to contact the community, in particular Chris Johns
> about the next logical step. This mail is regarding the same. I am very
> keen on contributing my ideas to this project. It would be great if the
> you can guide me on how I can begin with this project and what all do we
> have to implement. My IRC username is richashi.
The project has evolved since the last GSoC work and I will update this
page.
We have a University student working on the project at the moment and I
welcome the GSoC effort to the project as well. There is plenty to do.
The major change is the desire to output CTF format data. This lets us
use tools such as Trace Compass
(https://www.polarsys.org/solutions/tracecompass) to help visualise the
output. Joel has recently met up with the LTTng team and this followed a
meeting Joel and I had with them at the last GSoC Mentors summit. They
are aware of our efforts which is nice.
The other major piece of work that now exists is the Trace Linker in the
RTEMS Tool Project (https://git.rtems.org/rtems-tools). The trace linker
is a symbol wrapping post link process that lets us inject code at the
function call level to capture input and output values or even state
information. There is a printk example which has proved useful for my work.
Further Jennifer has updated the capture engine to work in SMP environments.
The tasks remaining are to bring together each of these parts so we can
generate a CTF file existing visualisation tools can display.
1. Integrate the trace linker to the capture engine.
2. Add enable and trigger configuration to the trace linker.
3. Extract capture engine logs from a target using gdb and python.
4. Generate command files for Babletrace from the trace linker.
5. Extend or use Babletrace to accept the capture engine output.
6. Generate function signatures by integrating libdwarf to the rtemstoolkit.
As we already have an existing person working on this code base we will
need to work as a team and this adds a little extra overhead to the GSoC
students and the mentors. We will need a suitable github repo of the
rtems-tool we can all push commits to and I can then upstream into the
RTEMS master repo. We will also need to define the various interfaces
between the different parts so they can be worked on.
