Fwd: [PATCH 000/111] GRLIB/LEON RTEMS RCC patches
Amar Takhar amar at rtems.org
Sat Mar 14 01:39:09 UTC 2015
> On 11/03/2015 1:27 am, Karel Gardas wrote:
> > Yes, this is a big patch but if you do not merge it now and later
> > following waf work you do tree/file placement refactoring than the patch
> > would be even harder to merge.
I was thinking this would land in 4.12 then waf would be based off of that.
4.12 would be released weeks after 4.11.1
There needs to be another branch for any 'bigger' changes to hit RTEMS after
4.11.
On 2015-03-14 11:25 +1100, Chris Johns wrote:
> Yes I tend to see this as important. It will be less overall work to
> merge before the source is changed.
> My support for merging sooner rather than latter is conditional on
> Daniel and team ensuring the SPARC and LEON BSP are tested and there are
> no regressions for 4.11.
As long as it's well tested and we redo all the testing Joel has already done..
Amar.
