[PATCH] autoconf changes
Sat Mar 14 21:05:44 UTC 2015
On 3/14/2015 3:44 PM, Ben Gras wrote:
> I accidentally also merged this commti when I meant to just merge the
> beagle one.e
> Should I revert it or is this ok to leave in?
Revert. I did a bootstrap and see two files that are different.
#    modified:   c/src/lib/libbsp/bfin/acinclude.m4
#    modified:   c/src/lib/libbsp/powerpc/acinclude.m4
No big deal. But it would be nice to know what host did it this time.
Chris has been fighting the sort order for a while. :(
--joel
> On Sat, Mar 14, 2015 at 8:08 PM, Gedare Bloom <gedare at gwu.edu> wrote:
>> Me too. I'm not sure why..
>> On Sat, Mar 14, 2015 at 1:44 PM, Ben Gras <beng at shrike-systems.com> wrote:
>>> Everytime I ./bootstrap && ./bootstrap -p, I get these changes
>>> w.r.t. mainline. Just tried again with a new tools build. (With the
>>> prefix/bin dir first in $PATH of course.)
>>> Or is it just me?
>>>  c/src/lib/libbsp/bfin/acinclude.m4    | 4 ++--
>>>  c/src/lib/libbsp/powerpc/acinclude.m4 | 4 ++--
>>>  2 files changed, 4 insertions(+), 4 deletions(-)
>>> diff --git a/c/src/lib/libbsp/bfin/acinclude.m4 b/c/src/lib/libbsp/bfin/acinclude.m4
>>> index ab6082e..828fd89 100644
>>> --- a/c/src/lib/libbsp/bfin/acinclude.m4
>>> +++ b/c/src/lib/libbsp/bfin/acinclude.m4
>>> @@ -2,12 +2,12 @@
>>>  AC_DEFUN([RTEMS_CHECK_BSPDIR],
>>>    case "$1" in
>>> -  TLL6527M )
>>> -    AC_CONFIG_SUBDIRS([TLL6527M]);;
>>>    bf537Stamp )
>>>      AC_CONFIG_SUBDIRS([bf537Stamp]);;
>>>    eZKit533 )
>>>      AC_CONFIG_SUBDIRS([eZKit533]);;
>>> +  TLL6527M )
>>> +    AC_CONFIG_SUBDIRS([TLL6527M]);;
>>>      AC_MSG_ERROR([Invalid BSP]);;
>>>    esac
>>> diff --git a/c/src/lib/libbsp/powerpc/acinclude.m4 b/c/src/lib/libbsp/powerpc/acinclude.m4
>>> index 6442399..e46fa2b 100644
>>> --- a/c/src/lib/libbsp/powerpc/acinclude.m4
>>> +++ b/c/src/lib/libbsp/powerpc/acinclude.m4
>>> @@ -38,12 +38,12 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
>>>      AC_CONFIG_SUBDIRS([t32mppc]);;
>>>    tqm8xx )
>>>      AC_CONFIG_SUBDIRS([tqm8xx]);;
>>> -  virtex )
>>> -    AC_CONFIG_SUBDIRS([virtex]);;
>>>    virtex4 )
>>>      AC_CONFIG_SUBDIRS([virtex4]);;
>>>    virtex5 )
>>>      AC_CONFIG_SUBDIRS([virtex5]);;
>>> +  virtex )
>>> +    AC_CONFIG_SUBDIRS([virtex]);;
>>>    esac
>>> 1.9.1
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
