Hello demo on RPI
André Marques
andre.lousa.marques at gmail.com
Sun Mar 15 15:19:30 UTC 2015
On 15-03-2015 12:32, Alan Cudmore wrote:
> Nice work Qiao!
> Andre had submitted the patches for GPIO, SPI, and I2C including
> recommended fixes. It was then recommended that we switch to the new
> Linux based I2C API, and we ( or I ) got stuck there.
I have addressed almost every Pavel's suggestion
(https://lists.rtems.org/pipermail/devel/2014-October/008911.html), and
the current code can be found on my last commit on my github
(https://github.com/asuol/rtems/commit/eca62b41521da2e606f38320d31c83ec82e30ab6).
The difference from the last patch is that now each interrupt handler
runs on its own task, and each user-defined handler may have as many
arguments as the user may want (through a void pointer). Each pin can
also have multiple handlers at the same time, so multiple devices may
share a GPIO pin for interrupts, in which case each handler must inform
if their device acknowledge the interrupt. The code is not yet
thread-safe, so locking and compiler barriers are still missing if they
are to be used on a concurrent environment, will try to conclude as soon
as possible.
> For the time I have available, it was not going to be a 1 or 2 day fix
> to move Andre's I2C implementation to the new Linux based API. It was
> taking me a while just to understand what needed to be done.
> A little later today, I will try to come up with a proposal to split
> the Pi work so it can be done by 3 participants.. But we need to
> decide if re-doing the I2C implementation should be part of the work,
> or if we should use Andre's initial implementation as a baseline for
> everyone.
As soon as GPIO is in SPI can be sent directly, and the I2C is just a
matter of using the new API, just refactoring the code around a bit to
the new API functions (still have not looked at the new API
unfortunately). Will have a look at it this week.
> Also, I will submit basic patches to create a raspberrypi2 BSP
> variant. I have built both the raspberrypi and raspberrypi2 BSPs and
> tested ticker so far.
I should receive my PI2 sometime this week, so I may be able to have a
look at it then.
--André.
> Alan
> On Sun, Mar 15, 2015 at 7:11 AM, Gedare Bloom <gedare at rtems.org
> <mailto:gedare at rtems.org>> wrote:
> On Sun, Mar 15, 2015 at 5:50 AM, QIAO YANG <yangqiao0505 at me.com
> <mailto:yangqiao0505 at me.com>> wrote:
> Hi !
> I've managed to run a hello demo on RPI B/B+, including a demo
> for loading an image by u-boot (I don't have an ethernet cable
> on my hand, but I'm going to be able to load the image by tftp
> for dev).
> If I've got it right, to prepare my proposal I may choose part
> of the TODO list , look into the implementation detail and
> schedule it. The work list may be divided for 3 students to
> complete.
> I've checked out the André's branch with GPIO, I2C, SPI
> implementations. Should we develop based on his branch or the
> upstream? Have we said that the I2C, SPI API has changed? I
> wonder that if anyone is working on it and if we will merge
> Andre's work to upstream at the begining of GSOC. If not,
> maybe I can get start by trying to do this job.
> The obvious projects I see from
> https://devel.rtems.org/wiki/Developer/Projects/Open/ImproveRaspberryPiBSP
> are:
> 1) Get #1-3 mergeable. May not take much. Then do #4 SD-card
> support and refactor the i2c to use the newer cpukit/dev/i2c
> interface.
> 2) #5 Graphics Frame Buffer + #7 HDMI/Graphics console
> 3) #6 USB + #7 Networking
> 4) Raspberry Pi 2 support, but this probably isn't enough.
> -Gedare
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150315/300d0336/attachment.html>
