Fwd: [PATCH 000/111] GRLIB/LEON RTEMS RCC patches
Sun Mar 15 21:29:51 UTC 2015
On 14/03/2015 12:39 pm, Amar Takhar wrote:
>> On 11/03/2015 1:27 am, Karel Gardas wrote:
>>> Yes, this is a big patch but if you do not merge it now and later
>>> following waf work you do tree/file placement refactoring than the patch
>>> would be even harder to merge.
> I was thinking this would land in 4.12 then waf would be based off of that.
> 4.12 would be released weeks after 4.11.1
> There needs to be another branch for any 'bigger' changes to hit RTEMS after
> 4.11.
Sure.
> On 2015-03-14 11:25 +1100, Chris Johns wrote:
>> Yes I tend to see this as important. It will be less overall work to
>> merge before the source is changed.
>> My support for merging sooner rather than latter is conditional on
>> Daniel and team ensuring the SPARC and LEON BSP are tested and there are
>> no regressions for 4.11.
> As long as it's well tested and we redo all the testing Joel has already done..
There are no tests in the patch set which is a key concern.
