rtems-source-builder on cygwin/64
emanuel stiebler emu at e-bbes.com
Mon Mar 16 10:05:21 UTC 2015
On 2015-03-15 22:19, Chris Johns wrote:>   [ back on list ]
I wasn't sure, people like to read this long log files ;-)
 > Thanks. Can you please try the attached windows.py ?
Sure. It "seems" to work. Is plowing through the sources for hours now ...
Will report, if it really works later ...
RTEMS Source Builder - Set Builder, v0.5.0
Build Set: 4.11/rtems-arm
Build Set: 4.11/rtems-autotools.bset
Build Set: 4.11/rtems-autotools-internal.bset
config: tools/rtems-autoconf-2.69-1.cfg
package: autoconf-2.69-x86_64-pc-cygwin-1
building: autoconf-2.69-x86_64-pc-cygwin-1
config: tools/rtems-automake-1.12.6-1.cfg
package: automake-1.12.6-x86_64-pc-cygwin-1
building: automake-1.12.6-x86_64-pc-cygwin-1
cleaning: autoconf-2.69-x86_64-pc-cygwin-1
cleaning: automake-1.12.6-x86_64-pc-cygwin-1
Build Set: Time 0:01:01.136507
Build Set: 4.11/rtems-autotools-base.bset
installing: autoconf-2.69-x86_64-pc-cygwin-1 -> /opt/rtems-4.11
installing: automake-1.12.6-x86_64-pc-cygwin-1 -> /opt/rtems-4.11
Build Set: Time 0:01:00.793307
Build Set: Time 0:02:01.929814
config: tools/rtems-binutils-2.24-1.cfg
package: arm-rtems4.11-binutils-2.24-x86_64-pc-cygwin-1
building: arm-rtems4.11-binutils-2.24-x86_64-pc-cygwin-1
config: tools/rtems-gcc-4.9.2-newlib-git-1.cfg
package:
arm-rtems4.11-gcc-4.9.2-newlib-b75c57950318ed657807f87a4c694e7b8d68fcae-x86_64-pc-cygwin-1
git: fetch: git://sourceware.org/git/newlib.git -> sources/git/newlib.git
git: reset: git://sourceware.org/git/newlib.git
git: checkout: git://sourceware.org/git/newlib.git => master
building:
