[rtems commit] IMFS: don't strlen() an unterminated string in IMFS_dir_read().
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Mar 16 18:36:59 UTC 2015
If an unterminated string is getting all the way to readdir()
and ls, doesn't that mean that somewhere a NULL wasn't
put on it when it was added to the directory entry?
A quick review makes me think imfs_creat.c and imfs_rename.c
at least do not appear to be accounting for the NULL.
On 3/16/2015 1:18 PM, Sebastian Huber wrote:
> Module: rtems
> Branch: master
> Commit: 674f8b1b050c7f6544424ea5c882878699dbc248
> Changeset: http://git.rtems.org/rtems/commit/?id=674f8b1b050c7f6544424ea5c882878699dbc248
> Author: Jamie Iles <jamie at jamieiles.com>
> Date: Mon Mar 16 17:23:36 2015 +0000
> a43a3466 (IMFS: Implement variable length node names) introduced a
> changed to IMFS_jnode_t from being a null terminated string to a
> separate unterminated string and length. IMFS_dir_read() was still
> performing a strlen() on this unterminated string though and when doing
> an 'ls' in the fileio example I saw that some filenames had garbage
> suffixes.
> cpukit/libfs/src/imfs/imfs_dir_default.c | 2 +-
> 1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/cpukit/libfs/src/imfs/imfs_dir_default.c b/cpukit/libfs/src/imfs/imfs_dir_default.c
> index 98f06df..2f12072 100644
> --- a/cpukit/libfs/src/imfs/imfs_dir_default.c
> +++ b/cpukit/libfs/src/imfs/imfs_dir_default.c
> @@ -73,7 +73,7 @@ static ssize_t IMFS_dir_read(
> dir_ent->d_off = current_entry;
> dir_ent->d_reclen = sizeof( *dir_ent );
> dir_ent->d_ino = IMFS_node_to_ino( imfs_node );
> - dir_ent->d_namlen = strlen( imfs_node->name );
> + dir_ent->d_namlen = imfs_node->namelen;
> memcpy( dir_ent->d_name, imfs_node->name, dir_ent->d_namlen + 1 );
> iop->offset += sizeof( *dir_ent );
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
