[rtems commit] rtems: make error codes uintptr_t
Gedare Bloom gedare at gwu.edu
Mon Mar 16 19:53:46 UTC 2015
On Mon, Mar 16, 2015 at 3:36 PM, Sebastian Huber
> ----- Gedare Bloom <gedare at gwu.edu> schrieb:
>> On Mon, Mar 16, 2015 at 2:23 PM, Sebastian Huber
>> > ----- Gedare Bloom <gedare at rtems.org> schrieb:
>> >> Module:    rtems
>> >> Branch:    master
>> >> Commit:    1ff449cfc473f6b88e1495492aebd665ad42b236
>> >> Changeset: http://git.rtems.org/rtems/commit/?id=1ff449cfc473f6b88e1495492aebd665ad42b236
>> >> Author:    Gedare Bloom <gedare at rtems.org>
>> >> Date:      Mon Mar 16 12:15:27 2015 -0400
>> >>  cpukit/score/include/rtems/score/interr.h | 2 +-
>> >>  1 file changed, 1 insertion(+), 1 deletion(-)
>> >> diff --git a/cpukit/score/include/rtems/score/interr.h b/cpukit/score/include/rtems/score/interr.h
>> >> index e0cedaf..7c2a604 100644
>> >> --- a/cpukit/score/include/rtems/score/interr.h
>> >> +++ b/cpukit/score/include/rtems/score/interr.h
>> >> @@ -164,7 +164,7 @@ typedef enum {
>> >>    INTERNAL_ERROR_RESOURCE_IN_USE
>> >>  } Internal_errors_Core_list;
>> >> -typedef uint32_t Internal_errors_t;
>> >> +typedef uintptr_t Internal_errors_t;
>> > This is a problem on 16-bit targets.  I suggest to use unsigned long here.
>> I guess this is fine as long as all 64-bit targets are LP64.
> The rtems_task_argument has a similar problem.  Maybe we need a new CPU type, e.g. CPU_Uintptr_and_at_least_32_bits.
OK, we could do something like
typedef unsigned long CPU_Uint32ptr;
in the 16-bit targets, and
typedef uintptr_t CPU_Uint32ptr;
in the rest, in their score/cpu.h files.
The only obvious alternative I see would be to limit strictly the
error code and task args to be int or ptr.
Gedare
> devel mailing list
> devel at rtems.org
