[GSoC] "RPi BSP improvement" idea separation
Yurii Shevtsov ungetch at gmail.com
Mon Mar 16 20:22:39 UTC 2015
These are called USB HID :-)
2015-03-16 22:17 GMT+02:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
> On 3/16/2015 2:57 PM, Yurii Shevtsov wrote:
>>> On 3/16/2015 2:37 PM, Gedare Bloom wrote:
>>>> On Mon, Mar 16, 2015 at 3:21 PM, Joel Sherrill
>>>> <joel.sherrill at oarcorp.com> wrote:
>>>>> I don't know if this has been posted or merged into the WIki.
>>>>> Alan, Gedare and I were discussing this earlier today. One thing
>>>>> to remember is that it is always possible something we think
>>>>> is 1/2 a summer is incredibly easy so bonus tasks should be
>>>>> defined for every student. In broad strokes, a possible breakdown
>>>>> could be.
>>>>> + Complete GPIO/I2C/SPI integration and add SD card
>>>>>   support (since it uses SPI)
>>>>> + USB and Network stack based on new BSP stack
>>> My understanding is that USB will need to be done first since
>>> the NIC is on the other side of USB.
>>> https://wiki.freebsd.org/FreeBSD/arm/Raspberry%20Pi
>>> makes it look like both USB and the NIC could come up easy.
>>> And there is the potential to leverage more code.
>>>>> + Raspberry Pi 2 optimization and SMP support
>>>>>   Basic support is merged but the cache is clearly
>>>>>   not in the right state based on benchmarks and
>>>>>   the MMU might need initialization based on an
>>>>>   early report from Alan. For sure, all capabilities
>>>>>   that work now or begin to work on the Pi1 will
>>>>>   need to be checked on Pi 2.
>>>> My intuition is there needs to be extra work added beyond just
>>>> fine-tuning the RPI2.
>>> +1 I just don't know what that is either. :)
>>>>> + User interface stack
>>>>>   This could include an HDMI/USB console, and perhaps a
>>>>>   port for the RTEMS graphics library. Obviously, you
>>>>>   can't use any USB devices for UI unless the USB stack
>>>>>   works so the USB effort would bring that up while
>>>>>   doing the graphics work. Then move to USB UI devices.
>>>> Avoid proposing any work that overlaps (conflict or dependent) on
>>>> another. No USB UI devices should be proposed.
>>> Yes. The first step of this one could be to get the Graphics Toolkit into
>>> the RSB.
>>> Then leave USB UI devices as bonus work.
>> BTW, what do you mean by USB UI device? Something like external video card?
> I am primarily thinking keyboard and mouse. User interface devices.
> The video should (hopefully) be usable without incorporating pure
> GPL code. FreeBSD and Minix should be references there.
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
