[PATCH 00/19] Warning clean up series
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Mar 16 20:29:17 UTC 2015
Hi
This is a series of patches focused on warning clean up. Most
are related to reducing the number of deprecated warnings
introduced by deprecating notepads, task variables, and
rtems_clock_get(). A few do touch printf() format warnings.
Some test and code rework is still left to get to the point
where all use of deprecated methods can be eliminated
very easily without impact.
--joel
Joel Sherrill (19):
cpukit/libdl/rtl-obj-comp.c: Use correct printf() specification
testsuites/samples/minimum/init.c: Notepads no longer need to be
disabled
tm07: Split some code into new spnotepad02.
mvme162/tod/tod.c: Do not use rtems_clock_get()
mvme167/network/network.c: Do not use rtems_clock_get()
beatnik/network/porting/if_xxx_rtems.c: Do not use rtems_clock_get()
score603e/tod/tod.c: Do not use rtems_clock_get()
powerpc/shared/flash/intelFlash.c: Do not use rtems_clock_get()
libcpu/bfin/clock/rtc.c: Do not use rtems_clock_get()
libchip/i2c/spi-memdrv.c: Do not use rtems_clock_get()
libchip/network/if_fxp.c: Do not use rtems_clock_get()
libmisc/monitor/mon-task.c: Disable deprecated warning for use of
notepads
Disable deprecated warning on implementation of deprecated methods
tests misc: Disable deprecated method usage warning when intentional
sptests misc: Update to not use deprecated methods
powerpc/mvme5500/vectors/exceptionhandler.c: Turn off deprecated
warning
powerpc/shared/flash/intelFlash.c: Eliminate use of deprecated method
cpukit/include/rtems/btimer.h: Improve brief
spcbssched03/tasks_periodic.c: Fixed now used before set warning
c/src/lib/libbsp/m68k/mvme162/tod/tod.c | 4 +-
c/src/lib/libbsp/m68k/mvme167/network/network.c | 40 +--
.../powerpc/beatnik/network/porting/if_xxx_rtems.c | 2 +-
.../powerpc/mvme5500/vectors/exceptionhandler.c | 6 +
c/src/lib/libbsp/powerpc/score603e/tod/tod.c | 4 +-
c/src/lib/libbsp/powerpc/shared/flash/intelFlash.c | 2 +-
c/src/lib/libcpu/bfin/clock/rtc.c | 4 +-
c/src/libchip/i2c/spi-memdrv.c | 11 +-
c/src/libchip/network/if_fxp.c | 2 +-
cpukit/include/rtems/btimer.h | 2 +-
cpukit/libdl/rtl-obj-comp.c | 2 +-
cpukit/libfs/src/rfs/rtems-rfs-buffer.c | 4 +-
cpukit/libmisc/monitor/mon-task.c | 23 +-
cpukit/rtems/src/clockget.c | 6 +
cpukit/rtems/src/taskgetnote.c | 5 +
cpukit/rtems/src/tasks.c | 14 +-
cpukit/rtems/src/tasksetnote.c | 5 +
cpukit/rtems/src/taskvariable_invoke_dtor.c | 5 +
cpukit/rtems/src/taskvariableadd.c | 5 +
cpukit/rtems/src/taskvariabledelete.c | 5 +
cpukit/rtems/src/taskvariableget.c | 5 +-
testsuites/psxtests/psxconfig01/init.c | 14 +-
testsuites/samples/minimum/init.c | 7 -
testsuites/sptests/Makefile.am | 2 +-
testsuites/sptests/configure.ac | 1 +
testsuites/sptests/sp07/init.c | 36 +--
testsuites/sptests/sp07/sp07.scn | 2 -
testsuites/sptests/sp07/task1.c | 5 +
testsuites/sptests/sp07/task2.c | 5 +
testsuites/sptests/spcbssched02/task_periodic.c | 6 +-
testsuites/sptests/spcbssched03/tasks_aperiodic.c | 6 +-
testsuites/sptests/spcbssched03/tasks_periodic.c | 7 +-
testsuites/sptests/spclockget/init.c | 2 +
testsuites/sptests/spedfsched03/tasks_aperiodic.c | 6 +-
testsuites/sptests/spedfsched03/tasks_periodic.c | 6 +-
testsuites/sptests/spnotepad01/init.c | 5 +
testsuites/sptests/spnotepad02/Makefile.am | 22 ++
testsuites/sptests/spnotepad02/init.c | 65 ++++
testsuites/sptests/spnotepad02/spnotepad02.doc | 0
testsuites/sptests/spnotepad02/spnotepad02.scn | 0
testsuites/sptests/spqreslib/task_periodic.c | 6 +-
testsuites/sptests/sptask_err04/task1.c | 344 +++++++++++----------
testsuites/tmtests/tm08/task1.c | 62 ++--
43 files changed, 478 insertions(+), 287 deletions(-)
create mode 100644 testsuites/sptests/spnotepad02/Makefile.am
create mode 100644 testsuites/sptests/spnotepad02/init.c
create mode 100644 testsuites/sptests/spnotepad02/spnotepad02.doc
create mode 100644 testsuites/sptests/spnotepad02/spnotepad02.scn
1.9.3
