[PATCH 11/19] libchip/network/if_fxp.c: Do not use rtems_clock_get()
Mon Mar 16 20:29:28 UTC 2015
 c/src/libchip/network/if_fxp.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/c/src/libchip/network/if_fxp.c b/c/src/libchip/network/if_fxp.c
index 6bcbd8b..9d223bb 100644
--- a/c/src/libchip/network/if_fxp.c
+++ b/c/src/libchip/network/if_fxp.c
@@ -415,7 +415,7 @@ rtems_fxp_attach(struct rtems_bsdnet_ifconfig *config, int attaching)
      * Set up some timing values
-    rtems_clock_get(RTEMS_CLOCK_GET_TICKS_PER_SECOND, &fxp_ticksPerSecond);
+	fxp_ticksPerSecond = rtems_clock_get_ticks_per_second();
 	DBGLVL_PRINTK(1,"fxp_attach called\n");
1.9.3
