rtems-source-builder on cygwin/64, WAF?
Tue Mar 17 10:41:01 UTC 2015
On 17/03/2015 2:48 am, Joel Sherrill wrote:
> Hmmm.. copying from the log you attached:
> This looks like somehow the the contents of
> ./rtemstoolkit/elftoolchain/libelf/_libelf_config.h are not being
> tripped by whatever conditionals are set on your host. I see FreeBSD,
> Apple, and Linux sections of the file.
> You can build rtems-tools by hand easily and see what's going
> wrong in that file. It may be as easy as adding "|| defined(__cygwin__)"
> or similar in the right place.
I have pushed a fix for this. It is building on Cygwin.
