RPi Support GSoC 2015
QIAO YANG
yangqiao0505 at me.com
Tue Mar 17 15:15:43 UTC 2015
Hi,
I've seen that you've compiled the kernel for SPARC, and run the sample with SPARC simulator. Maybe you should try to build the arm cross-compiler, compile the RPI BSP and run it on a arm simulator ( ex: QEMU) or on a RPI board?
Up to now I've seen you, Rohini and I who are willing to contribute for RPI BSP. Maybe we can share informations, references or ideas to prepare the proposal for the three part of work
Cheers!
On Mar 17, 2015, at 10:56 PM, Yurii Shevtsov <ungetch at gmail.com> wrote:
> Patch:
> diff --git a/testsuites/samples/hello/init.c b/testsuites/samples/hello/init.c
> index d8fe450..8bf3604 100644
> --- a/testsuites/samples/hello/init.c
> +++ b/testsuites/samples/hello/init.c
> @@ -28,7 +28,9 @@ rtems_task Init(
> rtems_test_begin();
> - printf( "Hello World\n" );
> + printf( "Hello RTEMS\n" );
> + printf( "This is Yurii's Hello world\n" );
> + printf( "Have a nice day\n" );
> rtems_test_end();
> exit( 0 );
> Image: http://habrastorage.org/files/ef9/936/a2c/ef9936a2c3134fd89d4f7cf80ec56bc8.png
> Working on hello for RPi
> 2015-03-13 18:19 GMT+02:00 Gedare Bloom <gedare at gwu.edu>:
>> On Fri, Mar 13, 2015 at 12:05 PM, Юрий Шевцов <ungetch at gmail.com> wrote:
>>> Am I right that completing Hello is just change and somehow submit lines in
>>> samples/hello/init.c ? And how can I submit the proof, of course?)
>> Correct. You can send an email here with patch attached and a link to
>> a screenshot posted somewhere.
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150317/ce72ecee/attachment-0001.html>
