rtems-source-builder on cygwin/64, WAF?
Tue Mar 17 16:37:36 UTC 2015
On 3/17/2015 11:30 AM, emanuel stiebler wrote:
> On 2015-03-17 11:41, Chris Johns wrote:> On 17/03/2015 2:48 am, Joel
> Sherrill wrote:
>  >> Hmmm.. copying from the log you attached:
>  >> This looks like somehow the the contents of
>  >> ./rtemstoolkit/elftoolchain/libelf/_libelf_config.h are not being
>  >> tripped by whatever conditionals are set on your host. I see FreeBSD,
>  >> Apple, and Linux sections of the file.
>  >> You can build rtems-tools by hand easily and see what's going
>  >> wrong in that file. It may be as easy as adding "|| defined(__cygwin__)"
>  >> or similar in the right place.
>  > I have pushed a fix for this. It is building on Cygwin.
> Which one did you update? I did a "git pull" on rtems-source-builder,
> and still got the same error ...
This was an issue in rtems-tools. Can you see if you can update that and
build it by hand?
RSB may need a hash tag updated and Chris might not have done that.
*** note sure on this ***
