Raspberry Pi 2 boot
Alan Cudmore
alan.cudmore at gmail.com
Wed Mar 18 18:45:38 UTC 2015
Jeff,
I have been running samples on the the RPI 2 by using the latest firmware:
https://github.com/raspberrypi/firmware/tree/master/boot
I just copied all of the files from the boot directory on my SD card.
I rename the sample ( ticker.ralf for example ) kernel7.img and it runs.
You can even copy a RPI 1 image to kernel.img and boot it using the same
card.
Alan
On Wed, Mar 18, 2015 at 2:41 PM, Jeff Mayes <Jeff.Mayes at oarcorp.com> wrote:
> Hi,
> I’ve built the Raspberry Pi 2 bsp and samples. My SD card has Raspian for
> the moment, and I don’t see a kernel.img file like the previous Raspberry
> had. So, how do I get “hello world” to run off the SD card?
> Thanks
> Jeff
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150318/83d8ec10/attachment.html>
