RPi Support GSoC 2015
QIAO YANG
yangqiao0505 at me.com
Wed Mar 18 20:07:56 UTC 2015
I've written a draft for implementing Frambuffer, HDMI console support and port graphic library tool kits for rpi.
Since I know little about the status of graphics tool kit at the moment and it would take some time for me to understand , I wonder what could be challenging for this part or could anyone give me some guidance or references? I'm looking into this part, any advice would help me boost.
Secondly, what is the status of current graphic kits and what should be done with the RSB? As gedare said:
>> adding the capability to build the library to the RTEMS Source Builder
I didn't quite understand it. Should we add the additional check/tools for the build environment in RSB or something else?
On Mar 18, 2015, at 05:17 AM, Yurii Shevtsov <ungetch at gmail.com> wrote:
> Hi)
> Right now arm cross-compiler is being compiled. And of course I will
> test Hello on actual RPi board. I would like to work with USB part of
> task as I mentioned here
> https://lists.rtems.org/pipermail/devel/2015-March/010462.html Which
> part would yo like to take?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150318/2b64efdc/attachment.html>
