[PATCH v2] score: Fix _Thread_Change_priority()
Wed Mar 18 20:31:19 UTC 2015
On 3/18/2015 3:20 PM, Sebastian Huber wrote:
> Atomically update the current priority of a thread and the wait queue.
> Serialize the scheduler update in a separate critical section with a
> generation number.
> New test sptests/spintrcritical23.
> Close #2310.
>  cpukit/score/include/rtems/score/thread.h          |   9 ++
>  cpukit/score/src/threadchangepriority.c            |  35 ++--
>  cpukit/score/src/threadinitialize.c                |   1 +
>  testsuites/sptests/Makefile.am                     |   1 +
>  testsuites/sptests/configure.ac                    |   1 +
>  testsuites/sptests/spintrcritical23/Makefile.am    |  22 +++
>  testsuites/sptests/spintrcritical23/init.c         | 177 +++++++++++++++++++++
>  .../sptests/spintrcritical23/spintrcritical23.doc  |  12 ++
>  .../sptests/spintrcritical23/spintrcritical23.scn  |   2 +
>  9 files changed, 246 insertions(+), 14 deletions(-)
>  create mode 100644 testsuites/sptests/spintrcritical23/Makefile.am
>  create mode 100644 testsuites/sptests/spintrcritical23/init.c
>  create mode 100644 testsuites/sptests/spintrcritical23/spintrcritical23.doc
>  create mode 100644 testsuites/sptests/spintrcritical23/spintrcritical23.scn
> diff --git a/cpukit/score/include/rtems/score/thread.h b/cpukit/score/include/rtems/score/thread.h
> index cea88f4..11f60f3 100644
> --- a/cpukit/score/include/rtems/score/thread.h
> +++ b/cpukit/score/include/rtems/score/thread.h
> @@ -582,6 +582,15 @@ struct Thread_Control_struct {
>    Priority_Control         current_priority;
>    /** This field is the base priority of this thread. */
>    Priority_Control         real_priority;
> +   * @brief Generation of the current priority value.
> +   * It is used in _Thread_Change_priority() to serialize the update of
> +   * priority related data structures.
> +  uint32_t                 priority_generation;
>    /** This field is the number of mutexes currently held by this thread. */
>    uint32_t                 resource_count;
>    /** This field is the blocking information for this thread. */
> diff --git a/cpukit/score/src/threadchangepriority.c b/cpukit/score/src/threadchangepriority.c
> index d61dfb8..6ee65f5 100644
> --- a/cpukit/score/src/threadchangepriority.c
> +++ b/cpukit/score/src/threadchangepriority.c
> @@ -29,29 +29,36 @@ void _Thread_Change_priority(
>    bool              prepend_it
> +  ISR_Level level;
> +  _ISR_Disable( level );
>     *  Do not bother recomputing all the priority related information if
>     *  we are not REALLY changing priority.
>    if ( the_thread->current_priority != new_priority ) {
> -    ISR_Level level;
> -    _ISR_Disable( level );
> +    uint32_t my_generation = the_thread->priority_generation + 1;
>      the_thread->current_priority = new_priority;
> +    the_thread->priority_generation = my_generation;
> -    if ( _States_Is_ready( the_thread->current_state ) ) {
> -      _Scheduler_Change_priority(
> -        the_thread,
> -        new_priority,
> -        prepend_it
> -    } else {
> -      _Scheduler_Update_priority( the_thread, new_priority );
> +    _Thread_queue_Requeue( the_thread->Wait.queue, the_thread );
Can we get a comment above this call that _Thread_queue_Requeue
checks that the thread is actually blocked on the specified queue so
we don't need to check the thread state?
> -    _ISR_Enable( level );
> +    _ISR_Flash( level );
> -    _Thread_queue_Requeue( the_thread->Wait.queue, the_thread );
> +    if ( the_thread->priority_generation == my_generation ) {
> +      if ( _States_Is_ready( the_thread->current_state ) ) {
> +        _Scheduler_Change_priority(
> +          the_thread,
> +          new_priority,
> +          prepend_it
> +      } else {
> +        _Scheduler_Update_priority( the_thread, new_priority );
> +  _ISR_Enable( level );
> diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
> index 934fea9..993d95f 100644
> --- a/cpukit/score/src/threadinitialize.c
> +++ b/cpukit/score/src/threadinitialize.c
> @@ -198,6 +198,7 @@ bool _Thread_Initialize(
>    the_thread->Wait.queue              = NULL;
>    the_thread->resource_count          = 0;
>    the_thread->real_priority           = priority;
> +  the_thread->priority_generation     = 0;
>    the_thread->Start.initial_priority  = priority;
>    _Thread_Wait_flags_set( the_thread, THREAD_WAIT_FLAGS_INITIAL );
> diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
> index 0d1e687..9025ff3 100644
> --- a/testsuites/sptests/Makefile.am
> +++ b/testsuites/sptests/Makefile.am
> @@ -37,6 +37,7 @@ if HAS_SMP
>  else
>  _SUBDIRS += sp29
>  endif
> +_SUBDIRS += spintrcritical23
>  _SUBDIRS += spatomic01
>  _SUBDIRS += spintrcritical22
>  _SUBDIRS += spsem03
> diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
> index eef901b..ae3c763 100644
> --- a/testsuites/sptests/configure.ac
> +++ b/testsuites/sptests/configure.ac
> @@ -40,6 +40,7 @@ AM_CONDITIONAL(HAS_SMP,test "$rtems_cv_RTEMS_SMP" = "yes")
>  # Explicitly list all Makefiles here
>  AC_CONFIG_FILES([Makefile
> +spintrcritical23/Makefile
>  spatomic01/Makefile
>  spglobalcon01/Makefile
>  spintrcritical22/Makefile
> diff --git a/testsuites/sptests/spintrcritical23/Makefile.am b/testsuites/sptests/spintrcritical23/Makefile.am
> new file mode 100644
> index 0000000..6baaf7b
> --- /dev/null
> +++ b/testsuites/sptests/spintrcritical23/Makefile.am
> @@ -0,0 +1,22 @@
> +rtems_tests_PROGRAMS = spintrcritical23
> +spintrcritical23_SOURCES = init.c
> +spintrcritical23_SOURCES += ../spintrcritical_support/intrcritical.h
> +spintrcritical23_SOURCES += ../spintrcritical_support/intrcritical.c
> +dist_rtems_tests_DATA = spintrcritical23.scn spintrcritical23.doc
> +include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
> +include $(top_srcdir)/../automake/compile.am
> +include $(top_srcdir)/../automake/leaf.am
> +AM_CPPFLAGS += -I$(top_srcdir)/../support/include
> +AM_CPPFLAGS += -I$(top_srcdir)/spintrcritical_support
> +LINK_OBJS = $(spintrcritical23_OBJECTS)
> +LINK_LIBS = $(spintrcritical23_LDLIBS)
> +spintrcritical23$(EXEEXT): $(spintrcritical23_OBJECTS) $(spintrcritical23_DEPENDENCIES)
> +       @rm -f spintrcritical23$(EXEEXT)
> +       $(make-exe)
> +include $(top_srcdir)/../automake/local.am
> diff --git a/testsuites/sptests/spintrcritical23/init.c b/testsuites/sptests/spintrcritical23/init.c
> index 0000000..01cb379
> --- /dev/null
> +++ b/testsuites/sptests/spintrcritical23/init.c
> @@ -0,0 +1,177 @@
> + * Copyright (c) 2015 embedded brains GmbH.  All rights reserved.
> + *  embedded brains GmbH
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> + *  <rtems at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.com/license/LICENSE.
> +#ifdef HAVE_CONFIG_H
> +  #include "config.h"
> +#endif
> +#include <tmacros.h>
> +#include <intrcritical.h>
> +#include <string.h>
> +#include <rtems.h>
> +#include <rtems/score/schedulerpriority.h>
> +#include <rtems/score/threadimpl.h>
> +const char rtems_test_name[] = "SPINTRCRITICAL 23";
> +typedef struct {
> +  RTEMS_INTERRUPT_LOCK_MEMBER(lock)
> +  rtems_id task_id;
> +  Thread_Control *tcb;
> +  rtems_task_priority next_priority;
> +  Scheduler_priority_Node scheduler_node;
> +  bool done;
> +} test_context;
> +static test_context ctx_instance;
> +static Thread_Control *get_tcb(rtems_id id)
> +  Objects_Locations location;
> +  tcb = _Thread_Get(id, &location);
> +  _Objects_Put(&tcb->Object);
> +  rtems_test_assert(tcb != NULL && location == OBJECTS_LOCAL);
> +  return tcb;
> +static bool scheduler_node_unchanged(const test_context *ctx)
> +   return memcmp(
> +     &ctx->scheduler_node,
> +     ctx->tcb->Scheduler.node,
> +     sizeof(ctx->scheduler_node)
> +   ) == 0;
> +static void change_priority(rtems_id timer, void *arg)
> +  /* The arg is NULL */
> +  test_context *ctx = &ctx_instance;
> +  rtems_interrupt_lock_context lock_context;
> +  rtems_task_priority my_priority;
> +  rtems_interrupt_lock_acquire(&ctx->lock, &lock_context);
> +  if (
> +    ctx->priority_generation != ctx->tcb->priority_generation
> +      && scheduler_node_unchanged(ctx)
> +    ctx->done = true;
> +  my_priority = ctx->next_priority;
> +  rtems_interrupt_lock_release(&ctx->lock, &lock_context);
> +  if (ctx->done) {
> +    rtems_status_code sc;
> +    sc = rtems_task_set_priority(
> +      ctx->task_id,
> +      my_priority,
> +      &my_priority
> +    rtems_test_assert(sc == RTEMS_SUCCESSFUL);
> +static bool test_body(void *arg)
> +  test_context *ctx = arg;
> +  rtems_task_priority last_priority;
> +  my_priority = 1 + (ctx->next_priority + 1) % 3;
> +  ctx->next_priority = 1 + (my_priority + 1) % 3;
> +  ctx->priority_generation = ctx->tcb->priority_generation;
> +  memcpy(
> +    ctx->task_id,
> +    my_priority,
> +    &last_priority
> +  if (ctx->done) {
> +      ctx->task_id,
> +      RTEMS_CURRENT_PRIORITY,
> +      &next_priority
> +    rtems_test_assert(next_priority == ctx->next_priority);
> +    rtems_test_assert(next_priority != my_priority);
> +  return ctx->done;
> +static void Init(rtems_task_argument arg)
> +  TEST_BEGIN();
> +  sc = rtems_task_create(
> +    rtems_build_name('T', 'E', 'S', 'T'),
> +    1,
> +    RTEMS_MINIMUM_STACK_SIZE,
> +    RTEMS_DEFAULT_MODES,
> +    RTEMS_DEFAULT_ATTRIBUTES,
> +    &ctx->task_id
> +  rtems_interrupt_lock_initialize(&ctx->lock, "Test");
> +  ctx->tcb = get_tcb(ctx->task_id);
> +  interrupt_critical_section_test(test_body, ctx, change_priority);
> +  rtems_test_assert(ctx->done);
> +  TEST_END();
> +  rtems_test_exit(0);
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> +#define CONFIGURE_MICROSECONDS_PER_TICK 1000
> +#define CONFIGURE_MAXIMUM_TASKS 2
> +#define CONFIGURE_MAXIMUM_TIMERS 1
> +#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 1
> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#include <rtems/confdefs.h>
> diff --git a/testsuites/sptests/spintrcritical23/spintrcritical23.doc b/testsuites/sptests/spintrcritical23/spintrcritical23.doc
> index 0000000..89e5281
> --- /dev/null
> +++ b/testsuites/sptests/spintrcritical23/spintrcritical23.doc
> @@ -0,0 +1,12 @@
> +This file describes the directives and concepts tested by this test set.
> +test set name: spintrcritical23
> +directives:
> +  - _Thread_Change_priority()
> +concepts:
> +  - Ensure that priority updates work if carried out in interrupt context while
> +    a priority change at task level is in progress.
> diff --git a/testsuites/sptests/spintrcritical23/spintrcritical23.scn b/testsuites/sptests/spintrcritical23/spintrcritical23.scn
> index 0000000..cea3292
> --- /dev/null
> +++ b/testsuites/sptests/spintrcritical23/spintrcritical23.scn
> @@ -0,0 +1,2 @@
> +*** BEGIN OF TEST SPINTRCRITICAL 23 ***
> +*** END OF TEST SPINTRCRITICAL 23 ***
> 2.1.4
> devel mailing list
> devel at rtems.org
