RTEMS build problem
Thu Mar 19 07:11:47 UTC 2015
On 19/03/2015 4:49 pm, Rohini Kulkarni wrote:
> There is an issue I've run into a few times. Everytime I run bootstrap
> script for rtems(say after restarting my machine) the bootstrap says
> autoconf version is not updated. So I have to build the toolset every
> such time when I have already built it and only want to compile rtems.
> Is there something that needs to be done that I'm missing out!
Is the build procedure asking you to set your path to the location of
the tools ?
This error is normally due your path not being set.
