RTEMS build problem
Gedare Bloom gedare at gwu.edu
Thu Mar 19 14:50:14 UTC 2015
You may add the export command to the file .bashrc in your home
directory ($HOME/.bashrc), so that it gets set every time you create a
new terminal window.
On Thu, Mar 19, 2015 at 4:08 AM, Rohini Kulkarni <krohini1593 at gmail.com> wrote:
> OK! I need to add this path to  $PATH.
> Got it. Thanks!
> On Thu, Mar 19, 2015 at 1:30 PM, Chris Johns <chrisj at rtems.org> wrote:
>> On 19/03/2015 6:23 pm, Rohini Kulkarni wrote:
>>> To tell exactly what I am doing, this is how I am updating the autoconf
>>> everytime with reference from the source builder documentation
>>> $ ../source-builder/sb-set-builder --log=l-4.11-at.txt
>>> --prefix=$HOME/development/rtems/4.11 4.11/rtems-autotools
>>> and then go on to build the toolset
>>> $ export PATH=~/development/rtems/4.11/bin:$PATH
>>> $ ../source-builder/sb-set-builder --log=l-4.11-sparc.txt
>>> --prefix=$HOME/development/rtems/4.11 4.11/rtems-sparc
>> After a reboot just do:
>> and the tools will work without needing to be rebuilt.
>> Chris
> Rohini Kulkarni
> devel mailing list
> devel at rtems.org
