imfs.h: warning cast from pointer to integer of different size
Ric Claus claus at slac.stanford.edu
Thu Mar 19 16:00:16 UTC 2015
On Mar 19, 2015, at 4:30 PM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> ----- Joel Sherrill <joel.sherrill at oarcorp.com> schrieb:
>> On March 19, 2015 9:52:56 AM CDT, Gedare Bloom <gedare at rtems.org> wrote:
>>> On Thu, Mar 19, 2015 at 10:49 AM, Joel Sherrill
>>> <joel.sherrill at oarcorp.com> wrote:
>>>> Hi
>>>> On one platform, we get a warning for this piece of code in imfs.h
>>>> static inline ino_t IMFS_node_to_ino( const IMFS_jnode_t *node )
>>>>  return (ino_t) node;
>>>> On this target, "typedef unsigned long ino_t;" and
>>>> sizeof(void *) < sizeof(unsigned long) so the cast is safe.
>>>> Would we be better off with ino_t being uintptr_t since we
>>>> do cast it back and forth?
>>>> Any other suggestions?
>>> The safest fix is to use the new CPU_Uint32ptr type. This resolves to
>>> uintptr_t on most 32-bit+ archs.
>> The type ino_t is defined in newlib so this doesn't work.
> The only requirement on the ino number is that it uniquely indentifies a node in a file system.  We only have a problem if sizeof(IMFS_jnode_t *) > sizeof(long).
I’m curious what you all think about doing:
  return (const char*)node - (const char*)0;
	Ric
