Minimum RTEMS system clock frequency
Fri Mar 20 00:27:29 UTC 2015
On March 19, 2015 7:22:03 PM CDT, Chris Johns <chrisj at rtems.org> wrote:
>On 19/03/2015 8:06 pm, Alexander Krutwig wrote:
>> currently I am working on the implementation of FreeBSD timecounters
>> into RTEMS as illustrated in Ticket #2271 of the developer's board
>> (https://devel.rtems.org/ticket/2271).
>This is really cool stuff and I think the graphs so far are excellent.
>> In the progress, I found out that the minimum RTEMS system clock
>> frequency should at least be 20Hz to guarantee a correct
>functionality.
>> Are there users that are troubled by this minimum system clock
>frequency?
>I am a little confused with the wording here.
>To me a 'system clock frequency' is the CPU clock or core clock or
>something similar. Is this a frequency of the tick interrupt for RTEMS
>If this is a tick frequency do you mean this is the maximum frequency ?
>A period of 50usecs is too short for any system I know of so I can only
>assume this is a maximum frequency and minimum period.
20 Hz is a 50 millisecond period.
I have assumed that he meant this was the largest clock tick time quantum which is reasonable to configure.
Why is that?
>If this is a maximum frequency that seems ok with me. This is a system
>timer and my experience is any high speed timing should use dedicated
>timers tailored to the task, or example IEEE 1588 (PTP).
>Chris
>_______________________________________________
>devel mailing list
>devel at rtems.org
>http://lists.rtems.org/mailman/listinfo/devel
--joel
