[rpi bsp] merging status of mailbox and the status of rtems graphics kits
André Marques andre.lousa.marques at gmail.com
Fri Mar 20 23:23:29 UTC 2015
Hello,
On 20-03-2015 20:59, QIAO YANG wrote:
> Hi,
> Since Andre is wiling to continue his work on buses and SD card
> support, and I'm preparing for the framebuffer implementation, I would
> like to know the status of Andre's mailbox implementation. If it
> cannot be merged yet, what is the problem? I may take this if the
> mailbox is not in Andre's planning.
since I have not touched the framebuffer last year I do not have any
implementation/patch for it (I did however used it to access some SD
host info in the past based on
https://github.com/jncronin/rpi-boot/blob/master/mbox.c).
If you intend to work with the framebuffer you may take it, as that
should be one of the first steps.
> What is the status of rtems graphics kits? Is anyone still working on
> it? I've found that the microwindows git server was not even reachable
> for the moment. I would like to know something about the kit so that I
> can have a clear plan to port the graphics libraries to raspberry pi
> and also the nano-x, microwindows. Or maybe we have better choice than
> microwindows?
> regards
