rsb build process - ftp error
Anand Krishnan
anandkp92 at gmail.com
Sat Mar 21 01:41:37 UTC 2015
yeah I do think that ftp is blocked. I was in a campus network.
Currently I am using another network, but its only a temporary setup. I
cannot download from ftp://ftp.gnu.org. But I can access http://ftp.gnu.org
I will check out the files mentioned, but in the download.py file,
ftp_downloader is an http_downloader itself.
On Sat, Mar 21, 2015 at 7:05 AM, Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> On 3/20/2015 8:14 PM, Anand Krishnan wrote:
> > Hi,
> > I am trying to build RSB for sparc. During the installation, it is
> > trying to download autoconf-2.69.tar.gz over ftp but fails.
> Is ftp blocked for you by a firewall? ftp.gnu.org is up and accessible
> to me.
> > Autoconf is already installed in my host machine. Why is it trying
> > again to download?
> Because it may or may not be the same version and patches as the one
> that is mated
> to the autoconf/make build infrastructure with RTEMS. I have at least a
> half dozen
> versions of automake and autoconf installed to deal with various GNU
> packages.
> > Also I think there is some error with downloading via ftp - is there
> > some way I can change the download through http?
> You can change that in these files.
> [joel at localhost rtems-source-builder]$ ls -1 source-builder/config/auto*
> source-builder/config/autoconf-2-1.cfg
> source-builder/config/automake-1-1.cfg
> > I am also attaching the log file.
> That shows ftp isn't working but not why. Can you get there manually?
> Is ftp a blocked service? or is there some other issue?
> > regards,
> > anand
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150321/ccbd154c/attachment-0001.html>
