GSOC 2015: Configuration GUI
Anand Krishnan
anandkp92 at gmail.com
Sat Mar 21 01:55:58 UTC 2015
Ok then, I'll work on it.
I'll check out WxPython and PyQt? Please let me know if they arent
suitable.
In the options.py file (
https://git.rtems.org/amar/waf.git/tree/rtems_waf/defaults/options.py),
there are multiple classes. The configuration supposed to set values for
each of this classes, isn't it?
On Sat, Mar 21, 2015 at 12:31 AM, Amar Takhar <verm at darkbeer.org> wrote:
> On 2015-03-19 12:32 +0530, Anand Krishnan wrote:
> > Dear Mentors,
> > I hope I am not too late. I am Anand Krishnan and I'd like to contribute
> to the
> > Configuration GUI project. I am a final year student at BITS Goa, India
> campus
> > and currently pursuing my Bachelor's thesis at IIT Bombay.
> You are not too late!
> > By cross platform, do we mean - different boards or OS or both? Do we
> have to
> > build the GUI to be able to run on a board or is it something like we
> run in
> > our PC and then burn the config file to the board? (like programming an
> > Arduino?)
> This program would need to run on Unix, OS X and Windows. It is meant for
> users
> of RTEMS to generate the config file used when building RTEMS. The
> results are
> used at build-time only.
> There are background libraries already written to handle the configuration
> options. The frontend needs to be written as well as bounds checking on
> some of
> the library classes in RTEMS Config. (The library used for configuration
> options
> in the waf build)
> Amar.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150321/668bd59e/attachment.html>
