[PATCH 00/42] Warning Removal Patch Series
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Mar 23 14:38:58 UTC 2015
This series of patches removes all but a few warnings from RTEMS. There
are some warnings which are false positives from GCC. But there are also
some warnings which require a newlib patch for inttypes.h that I just
committed and others which are flase positives in gcc versions less
than 4.9. In particular the h8300 has warnings which disappear with
a newer gcc.
Most of these patches are very small and intentionally so. I didn't
want to combine them. Each is single purpose and up for discussion.
Please review and I will push later.
--joel
Joel Sherrill (42):
cpukit/libmisc/shell/main_df.c: Eliminate printf() format warning
cpukit/libmisc/shell/hexdump-conv.c: Eliminate printf() format warning
tools/build/rtems-test-check: Support multiple include files
testsuites/testdata: Add sets to disable all jffs2 and mrfs tests
avrtest: Disable jffs2 and mrfs tests
h8sim: Disable jffs2 and mrfs tests
m32cbsp: Disable jffs2 and mrfs tests
testsuites/psxtests/psxsignal03/init.c: Fix line wrap
avrtest-testsuite.tcfg: Add tests with data size issues
h8sim*-testsuite.tcfg: Add tests with data size issues
m32csim-testsuite.tcfg: Add tests with data size issues
libcrypt/crypt-md5.c: Fix overflow issues
imfs.h: Add cast to remove warning for pointer/integer size mismatch
capture/capture_support.c: Fix printf() warning and formatting
dummy/default-configuration.c: Tune configuration down for small
targets
shell/utils-cp.c: Avoid redefinition of TIMESPEC_TO_TIMEVAL
malloctest/init.c: Fix use uninitialized warning
psxtests/psx15/init.c: Correct printf() warning
psxconfig01/init.c: Correct pointer/integer size warning
sptests/sp12/pritask.c: Correct printf() warning
sptests/sp13/system.h: Fine tune message buffer configuration to avoid
integer overflow
sptests/sp20: Reduce memory requirements
sptests/sp33/init.c: Correct printf() warning
sptests/sp34/changepri.c: Correct printf() warning
sptests/spatomic01/init.c: Avoid integer overflow
sptests/spedfsched02: Reduce stack space usage to fix on smaller
targets
sptests/spwatchdog/init.c: Avoid integer overflow
rtems/score/tls.h: Add casts to eliminate warnings on some targets
sptls01/init.c: Use larger data types for values
sptls03/init.c: Make type and constants uint32_t to avoid overflow
warnings
tools/build/binpatch.c: Include <unistd.h> for getopt()
lpc176x/console/console-config.c: Conditionalize code to avoid unused
warnings
nds/libnds/source/arm7/clock.c: Avoid over indexing array
nds/libnds/source/arm9/image.c: Add needed cast
mrm332/console/sci.c: Make routines static
tools/cpu/nios2/ptf.c: Add include of <ctype.h>
moxie machine type not supported by rtems-syms. See #2213
libdl/rtl-mdreloc-moxie.c: Fix printf() format warnings
samples/minimum/init.c: Add cast to avoid warning
testsuites/sptests/sp54/init.c: Add cast to avoid warning
libdl/rtl-shell.c: Adjust printf() format for off_t based on target
cpukit/libmisc/utf8proc/utf8proc.c: Avoid overflow
.../libbsp/arm/lpc176x/console/console-config.c | 4 +++
.../lib/libbsp/arm/nds/libnds/source/arm7/clock.c | 2 +-
.../lib/libbsp/arm/nds/libnds/source/arm9/image.c | 2 +-
.../avr/avrtest/make/custom/avrtest-testsuite.tcfg | 7 +++++
.../h8300/h8sim/make/custom/h8sim-testsuite.tcfg | 6 ++++-
.../h8300/h8sim/make/custom/h8sxsim-testsuite.tcfg | 8 ++++++
.../m32cbsp/make/custom/m32csim-testsuite.tcfg | 15 +++++------
c/src/lib/libbsp/m68k/mrm332/console/sci.c | 8 +++---
.../moxiesim/make/custom/moxiesim-testsuite.tcfg | 1 +
cpukit/libcrypt/crypt-md5.c | 12 +++++++++
cpukit/libdl/rtl-mdreloc-mips.c | 8 +++---
cpukit/libdl/rtl-mdreloc-moxie.c | 2 +-
cpukit/libdl/rtl-shell.c | 14 +++++-----
cpukit/libfs/src/imfs/imfs.h | 2 +-
cpukit/libmisc/capture/capture_support.c | 24 +++++++++--------
cpukit/libmisc/dummy/default-configuration.c | 14 +++++++---
cpukit/libmisc/shell/hexdump-conv.c | 6 ++++-
cpukit/libmisc/shell/main_df.c | 5 ++--
cpukit/libmisc/shell/utils-cp.c | 9 +++++++
cpukit/libmisc/utf8proc/utf8proc.c | 5 ++++
cpukit/score/include/rtems/score/tls.h | 12 ++++++---
testsuites/libtests/malloctest/init.c | 3 +++
testsuites/psxtests/psx15/init.c | 4 ++-
testsuites/psxtests/psxconfig01/init.c | 2 +-
testsuites/psxtests/psxsignal03/init.c | 6 ++++-
testsuites/samples/minimum/init.c | 2 +-
testsuites/sptests/sp12/pritask.c | 7 ++---
testsuites/sptests/sp13/system.h | 30 ++++++++++++----------
testsuites/sptests/sp20/init.c | 2 +-
testsuites/sptests/sp20/system.h | 2 --
testsuites/sptests/sp33/init.c | 5 ++--
testsuites/sptests/sp34/changepri.c | 9 ++++---
testsuites/sptests/sp54/init.c | 2 +-
testsuites/sptests/spatomic01/init.c | 19 ++++++++------
testsuites/sptests/spedfsched02/init.c | 2 +-
testsuites/sptests/spedfsched02/system.h | 2 --
testsuites/sptests/sptls01/init.c | 10 ++++----
testsuites/sptests/sptls03/init.c | 8 +++---
testsuites/sptests/spwatchdog/init.c | 10 ++++++--
testsuites/testdata/disable-jffs2-tests.tcfg | 12 +++++++++
testsuites/testdata/disable-mrfs-tests.tcfg | 13 ++++++++++
tools/build/binpatch.c | 1 +
tools/build/rtems-test-check | 2 +-
tools/cpu/nios2/ptf.c | 1 +
44 files changed, 220 insertions(+), 100 deletions(-)
create mode 100644 testsuites/testdata/disable-jffs2-tests.tcfg
create mode 100644 testsuites/testdata/disable-mrfs-tests.tcfg
1.9.3
