[PATCH 27/42] sptests/spwatchdog/init.c: Avoid integer overflow
Mon Mar 23 14:39:25 UTC 2015
 testsuites/sptests/spwatchdog/init.c | 10 ++++++++--
 1 file changed, 8 insertions(+), 2 deletions(-)
diff --git a/testsuites/sptests/spwatchdog/init.c b/testsuites/sptests/spwatchdog/init.c
index 8e329a4..1d3cb2f 100644
--- a/testsuites/sptests/spwatchdog/init.c
+++ b/testsuites/sptests/spwatchdog/init.c
@@ -36,9 +36,15 @@ static void test_watchdog_routine( Objects_Id id, void *arg )
 static void test_watchdog_static_init( void )
+  #if defined(RTEMS_USE_16_BIT_OBJECT)
+    #define JUNK_ID 0x1234
+  #else
+    #define JUNK_ID 0x12345678
+  #endif
   static Watchdog_Control a = WATCHDOG_INITIALIZER(
     test_watchdog_routine,
-    0x12345678,
+    JUNK_ID,
     (void *) 0xdeadbeef
   Watchdog_Control b;
@@ -47,7 +53,7 @@ static void test_watchdog_static_init( void )
   _Watchdog_Initialize(
     &b,
-    0x12345678,
+    JUNK_ID,
     (void *) 0xdeadbeef
1.9.3
