[PATCH 12/42] libcrypt/crypt-md5.c: Fix overflow issues
Gedare Bloom gedare at gwu.edu
Mon Mar 23 15:51:13 UTC 2015
I guess this is a problem for 16-bit targets? changing the constants
to 16UL and 8UL also should work. A comment should be made that this
is only for 16-bit targets. If we rid RTEMS of those, we can get rid
of some of these shenanigans...
On Mon, Mar 23, 2015 at 10:39 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
>  cpukit/libcrypt/crypt-md5.c | 12 ++++++++++++
>  1 file changed, 12 insertions(+)
> diff --git a/cpukit/libcrypt/crypt-md5.c b/cpukit/libcrypt/crypt-md5.c
> index c60dcf8..78ae0bc 100644
> --- a/cpukit/libcrypt/crypt-md5.c
> +++ b/cpukit/libcrypt/crypt-md5.c
> @@ -133,6 +133,17 @@ crypt_md5_r(const char *pw, const char *salt, struct crypt_data *data)
>         p = passwd + strlen(passwd);
> +#if defined(__rtems__)
> +       l = ((long int) final[ 0]<<16) | ((long int) final[ 6]<<8) | final[12];
> +       _crypt_to64(p, l, 4); p += 4;
> +       l = ((long int) final[ 1]<<16) | ((long int) final[ 7]<<8) | final[13];
> +       l = ((long int) final[ 2]<<16) | ((long int) final[ 8]<<8) | final[14];
> +       l = ((long int) final[ 3]<<16) | ((long int) final[ 9]<<8) | final[15];
> +       l = ((long int) final[ 4]<<16) | ((long int) final[10]<<8) | final[ 5];
> +#else
>         l = (final[ 0]<<16) | (final[ 6]<<8) | final[12];
>         l = (final[ 1]<<16) | (final[ 7]<<8) | final[13];
> @@ -142,6 +153,7 @@ crypt_md5_r(const char *pw, const char *salt, struct crypt_data *data)
>         l = (final[ 3]<<16) | (final[ 9]<<8) | final[15];
>         l = (final[ 4]<<16) | (final[10]<<8) | final[ 5];
> +#endif
>         l = final[11];
>         _crypt_to64(p, l, 2); p += 2;
> 1.9.3
> devel mailing list
> devel at rtems.org
