[PATCH] sparc: Ensure interrupt service after ISR enable
Daniel Hellstrom daniel at gaisler.com
Wed Mar 25 10:55:08 UTC 2015
Looks good. Please apply it.
danielh
On 03/25/2015 11:42 AM, Sebastian Huber wrote:
>   cpukit/score/cpu/sparc/rtems/score/sparc.h | 9 ++++++++-
>   1 file changed, 8 insertions(+), 1 deletion(-)
> diff --git a/cpukit/score/cpu/sparc/rtems/score/sparc.h b/cpukit/score/cpu/sparc/rtems/score/sparc.h
> index ac8c510..45df6ff 100644
> --- a/cpukit/score/cpu/sparc/rtems/score/sparc.h
> +++ b/cpukit/score/cpu/sparc/rtems/score/sparc.h
> @@ -320,7 +320,14 @@ static inline uint32_t sparc_disable_interrupts(void)
>   static inline void sparc_enable_interrupts(uint32_t psr)
>     register uint32_t _psr __asm__("g1") = psr; /* input to trap handler */
> -  __asm__ volatile ( "ta %0\n" :: "i" (SPARC_SWTRAP_IRQEN), "r" (_psr));
> +   * The trap instruction has a higher trap priority than the interrupts
> +   * according to "The SPARC Architecture Manual: Version 8", Table 7-1
> +   * "Exception and Interrupt Request Priority and tt Values".  Add a nop to
> +   * prevent a trap instruction right after the interrupt enable trap.
> +  __asm__ volatile ( "ta %0\nnop\n" :: "i" (SPARC_SWTRAP_IRQEN), "r" (_psr));
